Looking to replace shocks and bent springs?
Looking for some input on what shocks are best for a 2005 F350 with minimal towing, looking for ride comfort so i'm not in a lumber wagon.
The truck has a 4" lift/level which is 3" in the back and 4" pucks in the front.
I do have an issue with my springs being bent a funny angle, and effectively rubbing on the frame carriage bolts making funny noises when flexing a certain way, gets funny looks all the time. I'm wondering if the pucks caused this, stock shocks with a lift? Installed wrong? I noticed most 4" lifts come with a radius arm drop bracket and this truck doesnt have one, possible reasoning?
Can get a picture or two if it helps the explanation
Well i don't expect it to be expensive regardless doing my own work, but i know those are big names you're throwing out there. I was hoping someone would comment on how to fix the springs, and maybe it's a common issue with wrong installs or something? Not that i know if they are installed wrong or not.
My old shocks are the rancho stocks that came factory i'm sure, with 215,000km now they're pretty greasy and dead. Front end bounces uncomfortably.
Shock wise i'm looking for better replacements, nothing like coilovers with double gas chambers or anything.
I've never been impressed with Rancho shocks......Look at the bottom of the shock and see if there is an extension added where they mount up...If not they probably got over extended which probably contributed to them being toast...If they are the originals they were due to be replaced anyway I'd guess..
I can only give opinion based on my experience...Ditch the pucks, get a quality taller spring, and quality shocks to match the spring size....Your truck will ride much better..
*I'm addressing the lumber wagon issue*
and yes poor install is probably causing the rub..
Whats on the back HUGE blocks I'd guess ??
The stock shocks do not have an extension, but i do know that when the outside gets greasy it usually means they're leaking, or leaked empty.
Also about my radius arm question, should there be a drop bracket for a 4inch lift?
Quality springs and shocks will help your ride a lot, yes...I would think they would help the rubbing but w/o actually seeing whats going on I'm taking a guess..
Its your call whether or not you want a slight rake or not..
and yes it seems like a quality lift should have a radius arm drop bracket..
Not trying to be a smart *** or anything but it sounds like someone took the cheapest possible route on your lift..
My truck came with Ready Lift already on it when I bought it used..
Big pucks up front, huge blocks in the rear, and Pro Comp shocks...The truck rode terrible and handled even worse......I feel your pain man !!
Bad part is quality stuff doesn't come cheap for these trucks..
Looking at the rust on top of those shocks you may have to cut the threaded shaft (not the shock) to get them off..
