1988 FSuperDuty 460 FlyWheel Starter Problem
The truck did not have a starter when purchased and the 184 tooth flywheel had to be replaced - I put a new 184 tooth flywheel and starter in and the teeth stripped within a week. I have been doing research and believe it needs 180 tooth flywheel based on the engine numbers some of which are hard to read. Can someone confirm this before I wreck another flywheel - the numbers are below along with links to the pictures for verification:
Block D9TE-AB (1979 or Later)
Side Valve Cover (?8VE-A2A) 1988
Transmission ZF S-5-47
Flywheel RF-D9TE-6380-BB (184 Tooth)
http://s3.postimg.org/58xu0kyc3/D9_TE_AB.jpg
http://s23.postimg.org/7xcmd50iz/Fly_Wheel.jpg
http://s23.postimg.org/b5h3q6msr/Transmission.jpg
http://s23.postimg.org/ytwllgjcb/Vin.jpg
jmfsms
05-01-2023 07:45 AM
PatrickFord1986
10-06-2017 07:22 AM
Slopetruck
16
02-26-2009 09:24 PM
padd54
07-18-2004 09:45 AM
