Replacing the "insulation" in am 90 e350?
The cover inside the cab has almost no insulation left. It gets hot and loud in the truck. Anyone know where I can buy some replacement material? I went to home Depot and thought about buying the insulation in the image, but didn't but it because it has a layer of paper, it might etc too hot in there and I did t want the paper to burn up.
Any suggestions?
Any suggestions?
I used an 1/8" layer of Coolz-It reflecting sticky back on the doghouse (facing the engine side), then put the stock doghouse insulation over that. If you don't have any doghouse insulation, you can find gasser (3/16" foam with a reflecting metal layer) versions of the stock unsulation at the junkyard all the time. As for diesel insulation (it's about 1/2" felt-like fabric), it's harder to find. However, you probably could run the gasser insulation, as long as you didn't have a turbo. I considered running two layers of the gasser insulation.
I wouldn't use the insulation you showed for that application. I did something similar to genscritper. I used this from Summit. It was listed as the Summit Brand stuff
Pulled the stock insulation and stuck it to the inside of the doghouse. Ended up with enough to do 1 coat on all of it and a 2nd on parts.
Then I put the stock insulation back on.
For the outside of the doghouse you can try and source a premade cover or you could use some kind of HD carpet attached with adhesive.
You can also purchase hood specific insulation from quite few vendors. Summit has a decent selection.
tiny1
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
10-13-2017 12:00 AM
Resendiz
08-04-2015 01:29 PM
sparr0
07-26-2015 06:39 PM
Stewart_H
50
02-23-2013 02:57 PM
STROKIN'IT7.3
36
04-01-2009 04:01 PM
