1. For you alls with carpeting, does the clutch actuating rod go through the carpet? Or is the carpet simply relief cut ?
1A. And if the rod does go through, does the clutch rod boot retaining plate go on top of the carpet??? How big is the hole? To the inner extent of the plate?
HIO, I have carpet in my manual shift 69 that had a mat. I put the rubber booty on the floor, cut a hole in the carpet and ran the clutch rod thru it. A relief cut, to me, seemed lazy. I'm sure I didn't answer your question, but that's my .02.
No carpet but a full front to back rubber mat. I cut a relief for the clutch pedal since I knew the mat would be coming back out multiple times. Why fight with the clutch rod every time for something that is only noticeable if you are looking for it?
Good point.
Also a good point... but it'll be staring back at me every time I climb in.
