7.3l idi water fuel seperator leak
That connector was for your WATER IN FUEL light. With this filter, you don't have any such sensor. Su just drain it every now and then.
Sticky thread on glow plugs: https://www.ford-trucks.com/forums/9...le-system.html
I have a 1993 7.3 IDI . My fue waterl filter was dripping. Replaced the filter and it still leaked. On the bottom of the filter Ford attached a drain assy. There is a small rubber seal that looks like a water faucet seal. You'll need to unscrew it to get at the seal. My Ford dealer was going to order it but I went to the local hardware store and bought a faucet seal (bib washer) that worked perfectly. at a 1/3 the price. Thriftco plumbing 9400280 or Sayco Bibb WA.2.
Received 3,090 Likes
on
So it seems as if the leak was coming from the filter itself. I removed the two piece and replaced it with a WIX one piece like you guys suggested and it was remarkably easy. I think the only issue now is watching it to see if the heater plug is leaking but after cleaning it off and letting the truck run for a while I have not noticed anything.
What do I do the the wire on the bottom? Can I just ziptie it somewhere?
yup, just tape the end up and zip tie it somewhere solid.
My dad said diesels do not like to start in the cold...
this is an old wives tale. my 88 7.3 IDI will start 20 below zero without plugging it in.as long as the glow plugs are working. it complains, and takes a while to warm up, but it fires up on one cycle of the glow plugs.
Rollin.IH.Coal
11-17-2011 06:34 PM
Doorgunner808
08-23-2006 09:11 PM
