Need a 2006 F350 6.0l
Hello,
I'm looking for a very specific truck. It needs to be a 2006 Ford F350 shortbed standard cab 6.0l diesel 4WD. Preferably the truck is wrecked. I really don't want to pay for a perfect truck but I am open to all options. All I need is the drivetrain. The cab and bed is getting trashed. The truck can be slightly newer or slightly older but please no early six liters. I'll also entertain a 7.3l truck of the same specs. Thanks for looking!
I have an '07 F350 HarleyD version 6.0... currently the trans needs rebuilt (direct clutch failed) but I have an identical trans that needs the pump rebuilt and should probably be taken apart and cleaned as the Torque Converter failed while it was installed in the truck. It has ~160K on the engine. It has 20" RBP wheels with Toyo MT Tires (~15K miles on them). Also has a B&W 5th Wheel hitch installed with a quickly removable top (about a $900 hitch)
New Parts (Within last 18 months):
Alternator (140A)
Starter
Trans wiring harness
2008 Upgraded Trans pan & filter
Upgraded PC-A & SSPC-D Solenoids
Sinister Diesel EGR Cooler & Oil Cooler
EGR Valve
Sinister Diesel Coolant filter kit
Fuel Pressure Regulator Update Kit
2 Hybrid Crank/ Deep Cycle Batteries
Mishimoto All-Aluminum Radiator
Degas Bottle
Fan clutch
The truck and both transmissions for $15K as-is. I live in Winslow, AZ.
Alternator (140A)
Starter
EGR Valve
Degas Bottle
Fan clutch
AllRightHauling
Vehicles for Sale
09-11-2014 11:06 AM
AS350Pilot
General Diesel Discussion
15
12-22-2013 01:12 AM
