Damper broke on my 292
Old 02-08-2019, 04:04 PM
Walston's Avatar
Walston
Walston is offline
Walston is a name known to allWalston is a name known to allWalston is a name known to allWalston is a name known to allWalston is a name known to allWalston is a name known to all
It was a piece of cake. Unbolt the old and remove and put the new one on. You may need a new seal depending on how old it is. I used a file and made a little groove to match the timing mark. I used the key slot as a line up reference
Old 02-10-2019, 08:31 PM
bjano00
bjano00 is offline
bjano00 is starting off with a positive reputation.
Walston I got my crank pulley/ harmonic balancer about 3/4 of the way on using the loaner install tool, but now it’s extremely slow Going with max effort on each wrench turn. Did you find it became very difficult for the last 1 1/2 inches or so? Thanks
Old 02-10-2019, 10:10 PM
charliemccraney
charliemccraney is online now
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
If it requires a lot of effort you should pull it back off and see what's going on. Make sure the nose of the crank is clean and smooth. Likewise with the inner bore of the damper. Since it's not original make sure it's not interfering with something. It shouldn't be but it's always wise to make sure.
If those look good then it might be that the damper is on the tight side of the tolerance and may need a hone to make it a hair larger so that it goes on more easily.
Old 02-11-2019, 05:10 AM
Walston's Avatar
Walston
Walston is offline
I had no such issue. I agree with Charlie.
Old 02-12-2019, 09:33 AM
robski_1970
robski_1970 is online now
robski_1970 is starting off with a positive reputation.
I found a spring company in Kentucky that is will to make them. $94 each. He would need a sample to make an accurate copy though.
contact [email protected]
Big Skier
31
02-27-2019 07:21 AM
Talltruck
06-06-2016 12:55 AM
Spktyr
23
01-11-2016 01:04 PM
PPrash
03-13-2010 12:16 PM
410 Highboy
02-12-2010 02:01 PM
Quick Reply: Damper broke on my 292
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
