CA SMOG Problems
I understand now why you're asking.
I too am well aware of the smog BS. My old F250 (now my daughters truck) didn't have an underhood sticker like my Ex does, so I ordered one from Parts Guy Ed back when Ed was still working at Ford, since my old F250 should have had one.
And while my present truck doesn't have an underhood sticker, thankfully my valve covers do have the proper stickers showing non-cat needed.
Thankful because Ed no longer works at Ford so I wouldn't be able to order one and...well....I too will leave it at that.
Stewart
As others have said, I would check other smog shops. I am in the Auburn, CA area and I went through a similar problem with 1 of my vehicles about 10 years ago. The third smog shop I tried I found an honest but non **** owner and he passed the vehicle with no problem. At each shop I explained why the other shops would not pass it and he didn't care about what he considered a non issue as long as the required parts were there. I would get the cat welded on and try other shops. I figured it was better to be upfront with each shop so I didn't waste time going through a smog check just to fail the visual.
The issue I have with the smog check in CA is that it's not a state-wide requirement. If you are close to a dense population, you are required to have a smog. If you live out in the sticks, they don't care. Take my county for instance (Riverside). The left half of Riverside County requires a smog check while the right half of the county does not require one.........
Update,
Still annoyed, but found an oem downpipe take off. Shop in chico happened to have one, so truck goes in monday to have them weld this thing together so I can finally get my tags. Going to look into that banks set up, but money is better spent fixing my girlfriends car so she can get to and from work safely. Thanks so much Y2KW57 for your research, soon as funds allow I will be getting that set up.
And hopefully someday I wont be stuck in Cali, but thats a whole different subject.
My brother still lives in Folsom and before he retired, his station (at least at one point in his career) was in Del Paso Heights.
Not a place for a first choice to buy a house.
Stewart
#29
Definitely not. Luckily we didn't have to live there, just work. We lived in Fair Oaks and Orangevale are before moving to Idaho. Folsom is a nice area to live, but has become too expensive over the last 20 years.
#30
It's definitely a very nice area to live...not so much Del Paso Heights.
Stewart
