Tool for removal of oil pressure sending unit - Ford Truck Enthusiasts Forums
Old 07-21-2015, 11:14 AM
jschluter jschluter is offline
jschluter is starting off with a positive reputation.
I have a '78 F-250 with the 351M engine.The oil pressure readings are erratic and I want to change out the sending unit. This unit is the long version for dashes with the gauge rather than the idiot light so some form of offset wrench will be required to reach the 9/16" nut under the sending unit body. I found a wrench at the local Ford dealer made by K-D tools but the legs on the wrench opened up when I tried to remove the old unit. I may try to heat treat this wrench to get a little more strength but in the meantime I called the specialty tool mfgs. like Snap-On and none of them can find a wrench to do this job. Since I can't be the only person wanting to replace this sending unit, there must be some wrench out there to do the job. Can anyone help???
Old 07-21-2015, 11:33 AM
79F150400M's Avatar
79F150400M 79F150400M is offline
79F150400M is starting off with a positive reputation.
Just a thought, but how about a crowsfoot?? When I changed mine a few years ago.....I used a 9/16 combo wrench. Climbed up over the top of the engine and started turning it. Another option would be to heat up a wrench with a torch and bend it into a 90 and have someone with a welder tack on a piece of iron for a handle. My Dad had one made years back for the distributor bolt.
Old 07-21-2015, 11:42 AM
orangeford's Avatar
orangeford orangeford is offline
orangeford is gaining momentum as a positive member of FTE.
You can buy some distributor wrenches (pre-bent). They are typically available at auto parts stores for cheap.
Old 07-21-2015, 11:55 AM
jackburtonme's Avatar
jackburtonme jackburtonme is offline
jackburtonme is starting off with a positive reputation.
They do make them....My Grandpa had one that I borrowed once and use on a 1972 Ford LTD with a 400. Worked slick.
oil sending unit socket | eBay
Old 07-21-2015, 12:12 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
If your replacing it you could just use a pipe wrench on the body or drill a hole clear through the body and stick a screw driver through it if there's enough clearance .. Last resort I would relocate the new one for easier access and abandon the old one ..
Old 07-21-2015, 12:28 PM
Dasher400's Avatar
Dasher400 Dasher400 is offline
Dasher400 is gaining momentum as a positive member of FTE.Dasher400 is gaining momentum as a positive member of FTE.
We're talking on the back behind the intake manifold right? A stubby box end wrench should take care of that easy enough, just approach from the back.
Old 07-22-2015, 04:36 PM
Crowsfeet too shallow an offset, stubby box ends too long, so I need to have your grandfather. Guess I'm just gonna have to build one. Thanks for the responses.
Oil Pressure Sending Unit Vs Oil Fill Plug 160SOAR 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-06-2017 09:05 AM
Craftsman - What has happened? Rusty_S Garage & Workshop 33 01-12-2017 02:05 AM
1990 F-150 302 weird oil pressure reading 88n94 1987 - 1996 F150 & Larger F-Series Trucks 4 10-24-2015 05:05 PM
351M oil pressure sending unit removal/installation jschluter 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-20-2015 09:23 AM
Oil pressure sending unit wrench size? Nick1911 1987 - 1996 F150 & Larger F-Series Trucks 1 08-10-2008 05:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
