Discuss the EcoBoost!
#286
2011 and 2016 ecoboost
I have had the first gen and 2 gen with the 6 auto trans. The 2011 was honestly under powered the turbos wouldnt put alot of boost out. Buy my 2016 that baby is a monster I have light the tires up doing 65 with a trailer on it and I was not expecting that. But I own a 2011 F150 5.0 and I love the big V8 over the ecoboost.
#288
3.5 ecoboost
I hated gmc bought the wife a denali yukon with 6.2 gmc v8 and I was jealous lol. My 5.0 couldn’t hang with the ecoboost. The best ford motor I’ve ever had was a straight 6 in my 1985 F150. It was a beast in the snow still haven’t had a 4 wheel drive thatgoes as good as that F150
#289
#290
Considering purchase of an RV and this plays into the mix of upgrading the truck to a Super Duty or keep it until it starts to need actual repairs.
I LOVE my ECO and get okay MPG for getting it used (had a new 2012 that I got to break in the engine myself, MPG was significantly higher), pulls everything I've put on it without struggle, even up small mountains. I'd hate to upgrade if I really don't need to this soon, but I will take a new truck just like anyone else.
#291
I currently have 118k on my 2012 3.5 ECO, bought it used with 70k or so jist over a year ago. Ran many highway miles from PA to Northern NY to ND and back, with some towing on many of the trips of an average 5k-7k. MPG has been fairly steady, started at about 13, did some immediate maintenance (oil to full synthetic, air filter, plug gap verification, fuel injection system, throttle body cleaning, etc). Plus began some basic driving style changes (slower starting from a stop, coasting more, cryise control wgen possible) and MPG's began creeping up. Now I'm fairly steady, averaging about 17-19 MPG combined, even when I must idle for longer warm-up times in the below zero temps of winter or the use of 4WD.
#292
GVRW = Gross Vehicle Weight Rating. This has nothing to do with your tow rating. It's the maximum your truck can legally weigh on its two axles and nothing more. And there's no way it's 9,800 lbs for an F150, probably in the 7,000 lb range.
GCWR = Gross Combined Weight Rating - This is the maximum combined weight that the entire rig can weigh, which includes the truck and trailer weight. You won't find this on any door sticker, it's exclusive to the towing guide and your owner's manual.
Max Trailer Weight - This is your GCWR, found in your manual, minus the weight of your truck. To be accurate, this includes the weight of the occupants, luggage, gas, etc.
Don't stress over the exact numbers IMHO, a few pounds over or under isn't going to matter much to the truck. Pay close attention to tongue weight, axle weights, and that your trailer brakes are working properly, though.
#294
I think you're confusing terms, which is really easy with all the acronyms involved.
#295
Need some input
I'm looking to buy a 2011 f150 with 3.5l EB it has 171000 miles on it. It is a one owner but no service records. The truck looks new and drives great. The engine sounds good no noises. I have cold started it with no noise or smoke. Any input would help. What do I need to look listen for. Thanks
#297
Lets hear it
Thanks for your input.
#298
I'm not trolling. I have read just about everything I can find about the 2011 f150 EB. The two big things that I see pop up are Timing chain and condensation in the intercooler. Does that sound about right ? Should I be worried about carbon build up ? What are your thoughts, am I off my rocker for thinking about buying this thing or do I see If I can get 300k or more out of it ?
But with any 171,000 mile vehicle, maintenance history means everything. Good maintenance and it might last you a good amount of time. Bad maintenance and it is a crap shoot.
You are right about the “most common” big issues for the eco boost, and the major being timing chain. Even then what you save by buying that high mileage might offset the cost of you have to replace the timing chain and components.
#299
So, is an ecoboost good for 300K even with perfect maintenance? Will the chassis still be any good? Does planned obsolescence ring any bells with anyone? What does the term "lifetime" really mean in the auto world?
Look, I put 225K on my old 1988 F-150. But, not before I had to replace the engine, clutch, every single system on the truck and then I ran into issues with the ventilation controls, some parts simply weren't available anymore and I had to make repairs without the benefit of plug and play parts swaps. Never again will I hold onto a vehicle that is that worn out. I'd rather make a payment.
#300
I dunno...that many miles over a 7-year period means they were likely highway miles. I've found a couple examples in the last couple years of EcoBoost-powered F150s with over 300K miles, both times the owners reported normal maintenance routines with conventional oil changes every 5-8,000 miles. I think it's quite possible that this truck would have similar service, but of course not everyone has that kind of luck.
Would a $2K repair bill be a big deal to you? If so, I'd keep that in mind when evaluating a truck with this many miles. If you have some money saved away for stuff like this, it may not be a bad deal.
