302 efi in 74 F250
302 efi in 74 F250
Hi guys,
I installed a ford 302 efi engine from a 1990 crown vic in a 74 F-250 using a Ron Francis wiring harness. The engine has been rebuilt and since it is a 25 year old set up all, (and I mean all) the sensors have been replaced as have the injectors, fuel pressure regulator, air bypass solenoid, coil, cap, rotor, plugs, and plug wires.
It runs rich and throws 42, 92, and 75 trouble codes, as there are no provisions for a brake on/off circuit I am wondering if the 75 code could be causing my 42 & 92 rich codes. I have been told that the 75 code will prevent the computer from going into closed loop operation and result in the engine running rich. Does anyone know if this is a valid argument; or know somewhere that will program this function out of the computer system?
It has a ECC-IV computer with a MAP sensor,(also new).
Thanks, I'm at my wits end trying to figure out the problem, the vacuum reading also seems low to me, fluctuating between 16 and 17 inches at idle.
Cylinder compression 165 lbs. or more on all cylinders and timing is correct.
Any help, insights, or suggestions will be greatly appreciated.
John
John
Coresair
33
06-22-2016 06:00 AM
JWGJR_H
11-01-2012 07:07 AM
Cruiseomatic
07-09-2008 12:32 AM
