My F250 build thread - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 01-29-2016, 08:18 PM
binuya's Avatar
binuya
binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Originally Posted by Jaime74656 View Post
Where would (could) I pick one up?
BTS is closest to you. E4OD | 4R100 | 5R110 Ford Diesel Powerstroke Transmissions
  #122
Old 01-29-2016, 08:33 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
I would get a BTS. He has a lifetime guarantee on his trans and he builds his for truck pulling.
  #123
Old 01-29-2016, 11:11 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
Jaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to behold
ok, so dows that mean the BTS is better then a John Woods transmission?
  #124
Old 01-30-2016, 07:11 AM
Skip1970's Avatar
Skip1970
Skip1970 is online now
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
looking good!
  #125
Old 01-30-2016, 09:28 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
It's just my opinion that BTS is the better one to get. But you should call them both up and talk to them and you make your own decision on which one you should get.
  #126
Old 01-30-2016, 03:40 PM
Jaime74656's Avatar
Jaime74656
Ok cool, will do, as for photobucket, now that its back up the pics of the dash with the last LED in place are now coming! YAY!! it looks sooooooo much nicer and brighter too!!
Full on brightness
Dimmed out
  #127
Old 02-07-2016, 04:25 PM
Jaime74656's Avatar
Jaime74656
Originally Posted by Skip1970 View Post
looking good!
Thanks Skip!
  #128
Old 02-07-2016, 11:07 PM
Syncrowave's Avatar
Syncrowave
Syncrowave is offline
Syncrowave is gaining momentum as a positive member of FTE.
Originally Posted by CampSpringsJohn View Post
It shuts off the water going to the heater core allowing the A/C to work better. Some of us just install a ball valve and manually turn it off, but this valve actually works like the valve in most other vehicles.
Is that why a lot of 7.3 F-250 owners report having problems getting the A/C to be cold? (I'm new to these trucks.) Sorry for the hijack.
  #129
Old 02-08-2016, 06:11 AM
Jaime74656's Avatar
Jaime74656
Pretty much hitting the nail on the head here
  #130
Old 02-08-2016, 07:58 AM
Syncrowave's Avatar
Syncrowave
Thanks, Jaime. I'll have to put one of those valves into mine.
One other question, if you put an inline ball valve in the line running to the heater core, do you have to add a bypass line to allow coolant to circulate, or can you just block that line?
  #131
Old 02-08-2016, 08:47 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
A bypass line would defeat the purpose of installing it. I turn mine off in the summer when it gets hot, and leave it off till I need the heater again. Last week it was about 55 degrees outside and I set the climate control to panel with the heat turned all the way down. The air coming through was so warm I had to either turn on the A/C or open the windows. With that valve installed, you can actually use the vent for what it's designed for. And using the Ford Ranger mod, it makes it nice that you don't have to open the hood to shut it off or on.
  #132
Old 02-08-2016, 09:50 AM
Syncrowave's Avatar
Syncrowave
No, what I meant was, do I need to put in a line for the coolant to still flow, but go around the heater core, instead of through the heater core?
In other words, is the heater core in "parallel" with the radiator, or in "series" with the radiator? I'm assuming it's in "parallel," and that blocking flow through the heater core won't affect engine cooling, but just want to make sure.
Again, sorry for the hijack. I searched for an answer to this but didn't find one.
  #133
Old 02-08-2016, 10:05 AM
CampSpringsJohn
OK, now I know what you're asking! No you do not. The Ford Ranger mod shuts the water flow off just like a ball valve does. The only difference is you can do it from inside the cab with the temperature control ****. With the ball valve, it's closed, or opened, until you pop the hood and flip it again.
  #134
Old 02-08-2016, 07:49 PM
Syncrowave's Avatar
Syncrowave
Thanks, John.
  #135
Old 02-08-2016, 07:53 PM
Jaime74656's Avatar
Jaime74656
The valve that I should have pictured (4 way valve) does the recirculating it's self isolating the heater core
Quick Reply: My F250 build thread
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
