what paint to use for spyder and ic tubes?
The tubes are so smooth powder coat is about the only thing that will hold up. Everything else I use night temp paint with cermanic from The parts store.
I just did the same thing. VHT FLameproof silver on the up-pipes, turbine housing, and center cartridge. Red 500deg engine enamel on the compressor housing. I didn't have time to do the spider and IC pipe, but they would have been red also.
Couple tips: make sure your hands stay completely clean/grease free while installing everything ( yeah, pretty much impossible), or the VHT flameproof will stain and cure that way. Also, the engine enamel is not nearly as chemical resistant as the label claims. I sprayed a little brake cleaner on a rag, to wipe off some oil mist. Even after a week and 1,000 + miles of driving, the rag came away some red on it.
norvillebob
02-03-2010 01:00 PM
