Extremely bumpy ride
Old Jul 11, 2015 | 08:32 PM
AIbandit's Avatar
AIbandit
My spine was damaged in an IED blast in Iraq a few years ago and my truck is getting harder and harder to drive. It sends every little bump up me. It looks like I have the original shocks on there.
What do you guys recommend for shocks or possibly seat upgrades or any other possible solutions. I love my truck and don't want have to get something else.
The most I haul is my jeep on a trailer and occasionally two jeeps (8000lbs)
Old Jul 11, 2015 | 09:41 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
The hi dollar Rancho shocks I have are adjustable, setting 1 is pretty darn soft.
Better bet might be new seat cushion. A good shop can set you up with something softer. Or even seats from a different vehicle, if you noticed any you like recently.
When I am not towing I air all 4 tires down to 55. That tames some bumps and I still get even tire wear. Running 285 Bridgestone Revo 2.
These things ride hard no two ways around it. Hopefully some combination of shocks/seat/air pressure will be good.
And thanks for your service!
Old Jul 11, 2015 | 11:32 PM
tonym17's Avatar
tonym17
whats tires are you running??
Old Jul 12, 2015 | 12:13 AM
AIbandit's Avatar
AIbandit
My tires are a bfg all terrain knock off.
My friends ram 2500 amazingly better.
Old Jul 12, 2015 | 10:17 AM
glockholiday's Avatar
glockholiday
Yeah cause the ram has front coil springs. And we're still riding on leafs.
I've heard great reviews from people who replaced their seat foam.
A suspension shop can build you new leafs that have a much softer spring rate but will still hold the weight. (More leafs per pack). But thats getting up there in $$$$ range where you might reconsider keeping the truck.
Old Jul 12, 2015 | 10:45 AM
Tugly's Avatar
Tugly
I am bracing for a Buck$Zooka round square in "Stinky's" nose - the leaf springs are sagging. The distance to the bump stop is supposed to be about 4", where Stinky has 2" up there. His flat front springs are also knocking on bumps, so the spacers are shot. New springs and maybe some two-stage Fox shocks might get the ride a bit more civil, but I doubt these 4-ton bricks on leafs will ever ride like anything with coil springs. You may very well be forced into revisiting ownership of such a beast.
Saying that - I know somebody who put an OTR truck seat (with an air suspension) in his F550 to tame the beast, and it works quite well.
Thank you for your service.
Old Jul 12, 2015 | 11:02 AM
crop harvester's Avatar
crop harvester
like mentioned lower air pressures,lighter duty shocks my Rancho 9000 shocks on lowest setting are still stiffer than the lighter duty shocks I pulled,experiment with a removable seat cushion,then with the more expensive things to try,seat modifications or replacement & lighter leaf springs,or coil spring mod which I don't think is practical.
Old Jul 12, 2015 | 12:17 PM
djed's Avatar
djed
My seat-of-the-pants feel is that replacing my shocks (with Bilstein 5300, I believe) didn't soften the ride.
I second the vote for a good auto upholstery shop.
Old Jul 12, 2015 | 05:47 PM
Tugly's Avatar
Tugly
I have tinkered with shocks, but the differences are barely discernible. I'm investigating the Roadmaster Active Suspension right now. [LINK]
Old Jul 13, 2015 | 12:18 PM
AIbandit's Avatar
AIbandit
Thanks for the suggestions
Are there any good links coil conversions around here? I saw mention of an 05 axle swap. Looks pretty easy and would net me a spare axle for my jeep.
Found a pretty good thread on it. This will probably be my target after I gather enough info, and probably some form of seat upgrade.
http://www.thedieselstop.com/forums/...9-04-a-304486/
hornsurgeon
1997 - 2003 F150
Mar 18, 2012 07:36 AM
45 ACP
Nov 16, 2010 03:21 PM
Troglodyte
Jan 25, 2007 09:17 PM
gdsqdcr
1997 - 2003 F150
Apr 27, 2006 10:38 AM
924x2150
Dec 16, 2002 01:13 PM
