It looks like you are going to use an electric fuel pump. Make sure you have a good regulator set no higher than 2.5 psi. It is really easy to flood the stock carburetor with too much fuel pressure.
Vegas, tell me more about the mini-starter if you don't mind. Manufacturer, part number, fabrications needed, etc.
I have the same engine as you and my stock starter is only so-so.
PineconeFord, I purchased the mini-starter from Gean at Flat O Products!
Stand up guy that has been a pleasure to work with. I had one of these mini-starters in a flathead 8BA I previously owned and it worked AWESOME! Also got that one from Gean.
Give him a call and I am sure he will help you out.
I sure wish I'd known about those mini starters six months ago. Dang those are sweet. I have the same new alternator mounting brackets as you - had to modify the base mount, and shave a whole bunch of the adjusting arm.
You're doing a first class job. Like it a lot.
