My New 2015 FX4 SuperDuty-Several Questions
Hi all,
Picked up my new 2015 SD FX4 a few days ago. I didn't plan on getting an FX4 but it had all the options I wanted and happened to be an FX4.
I test drove and looked at several SD's at local dealers and most of the trucks had rake. When I took delivery, I noticed there was much rake to my truck; which is fine. I did some measuring of the fenders and this is what I found:
front passenger 41"
front driver 40.5"
rear passenger 41.5"
rear driver 41.5"
Top of front bumper
passenger 32.25"
driver 32"
Sits a bit low on driver side which from what I read is withing specs and normal.
Before taking delivery, I planned on adding a leveling kit, but it doesn't appear I need to. Is this normal for new trucks or maybe the FX4's sit more level? I do not have the snow plow or camper option. I did find a thread where a guy said his FX4 sat level upon delivery and the dealer could not explain why.
So, my 275/70/18 tires look like pizza cutter donut tires. I need some more rubber to beef things up a bit. I need some help with this. I read more than I post here but I am scratching my head on this. I have looked at countless threads here and other SD forums to try and find what I need to know.
I want new tires, in the 34-35" range if possible. I don't however want to add a ton of weight with a 75-80lb tire. Yes, picky I know. I also don't completely understand backspacing and offset. Seems negative offset pushes the edge of tire out, positive pushes it in. I get that, but when you talk backspacing I get lost.
From what I can find, the factory 18x8 wheel is +31mm and backspace is 5.72?
So what can I run with my factory set up? Looks like most tires need to be mounted on a 9" wide rim but factory is only 8". So I will likely need new rims; okay, but now I get a headache. Found some new Dick Cepek's I really like. The DC Blackout; the come in the following config's
5.7 backspace and +18 offset or
5 backspace and 0 offset.
Can a 34-35" tire fit on these wheels with factory specs I posted above?
I don't want the tire hanging out alot on the side. I guess the +18 offset will keep them tucked in a bit, not sure if they will fit/rub however.
I have other questions but these are the major ones right now.
Tires I am looking at are 325/65R18, 305/70/R18, 295/70/R18. Brands of Cooper ST MAXX, GY Duratrac, BFG........which AT tires in the 34-35" should I also look at? Don't need anything too aggressive. Thanks guys.
front passenger 41"
front driver 40.5"
rear driver 41.5"
Top of front bumper
passenger 32.25"
driver 32"
Don't know the offset/backspace. I got them when I originally got the Duratracs for winter tires (have two sets of tires). They were not soecial order or anything; just basic 18" rims.
How does the truck handle the heavy tires? Search for gears? Downshift alot? Terrible MPG's?
I have the 3.73 gears and the truck struggles to hold 6th on the highway up hills.
I'm not towing anything heavy yet, but I think the 4.30 or better gears would be mandatory with tires this size for towing.
It doesn't seem to burn any more fuel than before, but its hard for me to calculate the MPG right now because I haven't had the speedometer flashed to correct it yet. I don't really know how many miles I'm actually going on each tank.
Guess my warrantee will last a little longer this way. LOL
