Late 77 Frame for 4X4
Hey gang - Somebody on here was asking me a few months back about converting their 65 or 66 (I think) 2 wheel drive into a 4 wheel drive. I am in the process of tearing down a late 77 F250 4X4 (not a highboy) and this frame will be available in various configurations and I can assist with your build if you want to put your truck body on this frame. Seacoast of New Hampshire. PM me for details.
The cab is a direct bolt on but the frame has to be drilled for the bed, the transmission tunnel will need to be cut out and replaced with the one from the 70's and you will have to use an 80's steering column with an adjustable shaft..
This is my build of the exact same thing
https://www.ford-trucks.com/forums/1...4x4-frame.html
The frames are the exact same up front but your f250 will be a long bed correct? That'll be your only issue if you have a short bed on the 60's body.. I have seen some interesting 'filler' ideas for the extra 2 or so feet..
What happened?
John
Highboys: 1967/76 F250 4WD - 1977 F250 4WD before serial number Y20,001 (February 1977).
1977 F250 4WD's from serial number Y20,001, 1978/79 F250 4WD's are not High Boys.
These 4WD's have a married transfer case, no in-cab fuel tank. In-cab fuel tank cancelled from serial number Y20,001 along with the High Boys.
High Boy is an enthusiasts term, it's not FoMoCo terminology. High Boys have a divorced transfer case and an in-cab fuel tank.
Thanks guys, the gent who was interested in the conversion contacted me. And to interject along with the other facts, 73-79 body parts are mostly interchangeable such as fenders, hood, grilles etc. So you come across a lot of Highboy fakers who change the later 78 and 79 grilles to early 77 or before. Easiest way to spot a true highboy: Divorced transfer case, positive arc front springs (77-½ and later changed to 3" wide front springs which have almost a negative arc and sit almost flat). The highboy (as ND correctly points out not a Ford term) actually sat 4" higher than the later 77, 78 & 79 truck - hence....highboy. Also - I think - ND can confirm - you wont find a highboy with a 351M. I think up to that split year in 77 the highboys all had FE's?? I might be reaching on that one..
(pic stolen off Google - no affiliation whatsoever)
Also, While Highboys have a 4" block under the rear springs, this does not mean they sit 4" higher as "Lowboys" have a 2" block. Therefore the height difference is closer to 2".
72f250CS
12-23-2003 10:09 PM
taz3fan
11-13-2002 05:33 PM
