Fuel delivery question
Old Jun 21, 2015 | 07:03 PM
Big-Dawg's Avatar
Big-Dawg
Hello all, I've got an 86 F-150 EFI with 302, auto w/overdrive. For a while now I've had issues with the fuel guage barely working for both tanks. I recently replaced the front tank sending unit with an aftermarket "Spectra Premium" & pump. It works great except for the float arm needing an adjustment. It now tells me I'm empty after 150 miles, and after not having a working guage, I know I'm good for at least 225 miles before I'm out. The issue I'm concerned with is, sometimes it feels as if I'm running out of fuel "skipping?" when its first started. I have noticed it doing the same near the end of a tank as well, after its warmed up. I had the same issue on the original sending units & just passed it off as a worn out pump. Could my fuel lines be introducing air & make the truck feel as if it's skipping? I mean they are 30 years old. And to let you all know, the Dist cap, button, plugs & wires have all been changed within the last 6 months. And I run Lucas injector cleaner evey other month on both tanks. I know this is a boatload of questions, but any help would be appreciated.
Old Jun 21, 2015 | 07:07 PM
Franklin2's Avatar
Franklin2
Water likes to lay down in the bottom of the tank. Put some dry gas in the tank and see if that makes the problem go away. It's just alcohol and will let the water mix with the fuel and pull it up out of the tank and burn it in the engine.
Old Jun 21, 2015 | 07:13 PM
Big-Dawg's Avatar
Big-Dawg
Franklin, Gas dryer additive? Would rubbing alcohol do the same thing? I'm sure I have a bottle of that here. Seems like I've heard of an old school mechanic doing that years ago.
Old Jun 21, 2015 | 07:16 PM
Franklin2's Avatar
Franklin2
Probably would do the same thing. If you buy the official stuff and take the cap off it smells the same as rubbing alcohol.
Old Jun 21, 2015 | 07:49 PM
Big-Dawg's Avatar
Big-Dawg
Thank you Franklin, I'll let you know how it turns out after I run through a tank or two. Thanks again!
Old Jun 21, 2015 | 11:11 PM
whisler's Avatar
whisler
Dri-Gas is usually methanol and rubbing alcohol is usually diluted isopropanol. Guess what it is diluted with...water. Dri-gas will work much better.
Old Jun 21, 2015 | 11:29 PM
Big-Dawg's Avatar
Big-Dawg
Thank you whisler. I'll see what I can find tomorrow & let y'all know.
maclif
34
Oct 12, 2016 11:44 PM
AndeyHall
Jan 7, 2010 07:22 PM
jimpennycuff
Apr 20, 2008 04:41 PM
desperado_18_2000
Mar 16, 2003 10:21 AM
therenys1
Nov 13, 2002 07:45 PM
