'88 F-350 Brake Caliper Mounting Bracket
Hey FTE!
A while back I had a bearing blow up on me and when I took my rotor and eveything else off, I found this...
So here's the problem...
I don't think that I want to put this back on my truck, but none of the junkyards around here stock 1-ton trucks for some stupid stupid reason...
So, does anyone know where I can get a new one? Or whether this one is still good?
Or if someone has an extra for some reason, I'd definitly be willing to purchase it from you!
Picks not working for me either, followed the link and looked around though, found this.
Well that's new, never seen that happen before.
If you're in a pinch I think your ok to run it until you find another, there is a lot of metal there.
As for finding a truck to gets parts off of, F350 4wd front axle stuff is hard to come by, everyone wants the front axle. But for this part the ones from a F250HD will work. F250HDs use a D50TTB and the D50TTB has identical caliper brackets.
You're looking to get them off of a F250 4WD Ex-cab, that truck should be easier to come by in a yard. F250 regular cab isn't HD, it will have a D44HD.
Received 3,106 Likes
on
AAubinoe
08-07-2015 04:33 PM
royzell
07-20-2009 09:38 PM
FlatBlack87350
06-11-2009 03:33 PM
cpnhgnjnky
12-29-2001 11:15 PM
