ZF5 speed trans serial numbers
Old 06-19-2015, 10:22 AM
Dflynn926's Avatar
Dflynn926
Dflynn926 is offline
I am sure someone has asked and answered this question already but I can not find it.
I have a ZF5, I was told it came from behind a 460, but someone told me the one I had came from a 7.3 or 6.9.
What are the serial numbers for a diesel and what are the ones for a 460?
I am trying to sell it and don't want to misinform a buyer.
Old 06-19-2015, 10:53 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Here is the break down for ZF5s. VERY SIMPLE
87-95 are S-42 variety rated @ 420ft/lbs
96/97 are S-47 variety rated at 470ft/lbs
ALL small block gas are INTERNAL slave and have a 5.72 1st gear(on tag on side)
ALL big block gas are EXTERNAL slave and have a 5.72 1st gear(on tag on side)
s-42 diesel are EXTERNAL slave and have a 4.14 1st gear(on tag on side)
s-47 diesel are EXTERNAL slave and have a 5.08 1st gear (on tag on side)
Old 06-21-2015, 01:17 AM
Dflynn926's Avatar
Dflynn926
Awesome thank you so much!
Old 05-13-2020, 12:44 PM
Steve Brann's Avatar
Steve Brann
Steve Brann is offline
So To use a Gas big block all ya need is to change the gear to a 5.08
Old 05-13-2020, 03:03 PM
farmert's Avatar
farmert
farmert is online now
The big block ford ZF tranny will not bolt up to a diesel engine. The bolt patterns are different.
Old 05-13-2020, 09:53 PM
nateairman's Avatar
nateairman
nateairman is offline
The top holes measure out the same. The lower holes are not correct but some make a ovalized hole to make it work. The alignment dowel doesn't line up.
Short answer no. Long answer is described by searching hybrid zf5 460 to 7.3
Old 05-13-2020, 10:07 PM
7.3 forever's Avatar
7.3 forever
7.3 forever is offline
I’ve taken the aluminum spacer off the back of the a 7.3 and used as a template several times to drill holes correctly. In a big block zf bellhousing works perfectly if done correctly.
Old 05-13-2020, 11:05 PM
nateairman's Avatar
nateairman
Did you drill for alignment dowels as well?
Old 05-14-2020, 05:08 AM
Diesel_Brad
no, you dont change the gears you. You would have to redrill the bellhousing pattern
With some careful measuring and drill it can be done
Old 05-14-2020, 05:09 AM
Diesel_Brad
yes, you also drill for the dowels
winemaker69
03-04-2012 03:09 PM
Twistedtesty
05-21-2010 08:15 PM
June Bug
02-22-2009 10:36 PM
barney9953
10-20-2007 12:19 PM
broncman
04-10-2007 08:46 AM
Quick Reply: ZF5 speed trans serial numbers
