Need the quickest way to mount a cargo rack to the Excursion factory rails
I leave for a one week trip on Saturday and need to throw some cargo on the roof of the Ex. I'm happy to buy a cargo rack but what do you guys suggest for mounting it to the factory racks? I know and am aware of the factory racks and how close they sit. I need a solution I can purchase on Amazon since I can get it within a day.
Let me know your thoughts and THANK YOU in advance.
Edit: Would this work with a couple extensions WITHOUT needing to purchase something like the Yakima roof rack system?
Amazon.com: CURT 18115 Roof Mounted Cargo Rack: Automotive
They slide around until you tighten them up and you are good to go, sorry no pics, did this prolly 10 years ago.
Check this reno for sale "yakima" - craigslist
between used and some new stuff you should be in fat city.
Take your factory rail bolts to lowes and get stainless ones that are about 1/2" longer. While there, pick up a rubber bushing with a brass insert that is slightly larger diameter than the bolt. Go home and take out the factory bolt, put the new bushing under the roof rail and fasten down tight to the factory threaded plate. Use washers as you see fit. I haul a Thule cascade roof box on it with no issues and it only raises the rails about 1/2" so parking garages are not an issue. As a plus, the rails no longer rub the roof. Good Luck!
Late response since you're leaving tomorrow but if you need a hardware store solution and you have a saw that will cut metal, you can use use what I did here:
hardware store cross bars
Any store bought cargo rack should be able to hook into the strut openings somehow.
TomFL
04-10-2016 01:52 PM
