F250 7.3 HPOP help!
Clean the oil out of the valley. Then, using a mirror on a stick with a flashlight, start the truck and watch the line fittings (both on the pump and each head), as well as taking a peek at the plug underneath the bottom of the HPOP.
Once the oil is cleaned up, you should be able to tell where it's coming from.
BluecreekGT
02-20-2019 07:56 PM
