I'm going to smoke my '99 E250 as I can't figure out a vac leak or two.
There are many DIY devices I see on YT.
My question is if I use a 12v inflator as a pressure source, what should I know about the max psi ? Is going through a gas grille 2 lb regulator the way to go or what ?
