Grinch is getting a new engine pan gasket, OBA, 38R. Step by step engine/trans removal W/ pics
#61
Pulling out the motor
With the A/C condenser out of the way and everything doubled check, I remove the 4 bolts holding the hood on and then it was time to pull the motor.
To pull the motor I used a heavy gauge piece of rebar and stuck it through both eye hooks on the block
I did not have a cheery picker, but I had a small tractor to give me a hand. With a heavy duty lifting chain and swivel hook I attached to the rebar.
Out she came.
Out she came.
#62
#63
#65
#66
Ive pulled plenty of gas engines in my day, mostly race car stuff which are generally much simpler to do because of the lack of anything not needed to go fast, but one of my biggest questions about pulling the 7.3 Powerstroke out of my 2001 to do the pan is : Can anyone confirm that this engine is too heavy to use a standard engine crane ???
My crane is a 2000 lb capacity, but that's with the boom all the way in and I dont think that it will reach in far enough that way, but I guess some measuring would tell me. I've got a friend that works on semis, am I better off trying to get a huge heavy duty crane from him, or the 7.3 not that heavy that it would be needed?
#67
I had my fun with the transmission!!! It sure was nice watching that tractor do the heavy lifting.
#68
#69
#70
on
Keep in mind if using a cherry picker with adjustable length boom...it has different ratings depending on how far you extend it.
Practical advice- I've always had more challenge ROLLING the lift after getting a load on it than anything. Hard smooth surface is best, forget about gravel unless you have plywood down
I can't get my tractor into the small garage for lifting, it takes up too much room
#71
How does the flat bottom of this pan manage the fluid when the transmission is at a very steep incline or decline? My understanding is that the bottom of the OEM pan is tapered at the rear and irregularly shaped in order to make certain that the pick-up tube on the internal filter screen is always adequately submerged in the sump no matter how steep of an incline or decline the transmission may be oriented at.
My concern would be how to balance the "fluid full" indication on the dipstick, with the full flatness of this aftermarket pan. The lack of any taper at the rear could mean that more fluid would pond back there when the trans was tilted up a severe incline (like a steep driveway), which could cause the pickup tube to suck air? A tapered pan would not allow the fluid to drop that low.
Overfilling the trans to make up for the additional volume of the flat pan may have other consequences when the transmission is level. I don't know... but those are the concerns I would have when looking at that pan, compared to the stock pan.
#72
#73
Great job, Scott! I'm drooling over that battery wire - my battery clamps are in dismal condition.
You're gunna need that upgrade in boost-containment hardware, and I see you're feeling a little blue.
I'm glad you're putting that boost gauge to work soon. We'll have to compare notes on my next visit. You figure the Grinch will be ready to battle-rap with Stinky by then?
#74
Cool, thanks Pikachu!!
Thanks Ed. The truck is actually 100% rust free and is in very good shape thanks to the west coast climate. Just needs a little scrubbing and some fresh paint and she will be back to new again.
Many more pics to come!
Rich, my battery cables were in bad shape at the connectors and needed a new one. I bought it from 1A auto for around 100 bucks. Thought it was a pretty good deal for what you get.
I wanted to wait for the boost gauge to be installed when I do the others, it's going to look nice in there with the rest of them.
I'm feeling ok, just moving slow and doing what my pelvis will allow.
I'm hopping that Grinch will be ready to drive by the end of the month. That is the goal any way.
Me too!! It's going to be an experiment thats for sure.
#75
