Superduty axle fit?
Superduty axle fit?
I have a 79 F-150 4x4 lariat and the rear end has seen better days. I also have a set of superduty axles front and rear off a 2001 F-250. I was wondering if they would fit under the 79 with little modification? If I do it I'd also install a 4" lift or so while I had it apart. Anyone know if this will work?
Thanks; Mike
Thanks; Mike
It has Dana 44 size u joints, which you have now, but a Dana 60 size pig to smash into everything and eat up all your ground clearance. It's basically the worst of both worlds, the main thing that makes people step up to one ton axles is shaft/u joint breakage.
