Safety question PICTURE ADDED !
Old 06-11-2015, 09:52 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
Originally Posted by OldGrayMare
As promised pictures of the PO's handy work. Sorry for the picture quality I got a little to close. As you can see the u-bolts are to short and not parallel with each other, nuts welded to axle, bolts welded to springs, spring center pin not over axle. Because the axle is longer the springs don't sit on the pads, u-bolts don't align with holes. The list goes on and on.
I already have the proper axle, new king pins, disk brake conversion, set of 5 on 5.5" wheels and tires. Still need to find some springs and new linkage.
Oh and the front wheels had the center hubs cut out and welded back together with hub caps over them to hide it.
PO must have liked to live on the edge!
Old 06-11-2015, 10:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Looks like he was blind, and his battery was running low, or the coathanger ran out. The three longest leaves at least are ruined, I'd say.
Old 06-11-2015, 10:57 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
I pride myself in being a accomplished butcher, but that surpasses even my skills.
That is some scary stuff, if that is indicative of the work done on the truck I would be inspecting everything carefully.
Time for new springs IMO, even though it looks like he may not have put enough heat them to hurt them.
Old 06-11-2015, 11:46 AM
purplewg's Avatar
purplewg
purplewg is offline
Yeah, when you get into stuff this old, you never know what you will find. I did some crap stuff back in the day when I had no money.
Old 06-11-2015, 11:51 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
I'm speechless! At least my PO didn't do any welding. Just ran it the way it was.
LR Spring
Old 06-11-2015, 12:05 PM
OldGrayMare's Avatar
OldGrayMare
OldGrayMare is offline
When i get a chance I will shoot a picture of the home made motor mount, welded wheel, and exhaust pipe made out of "pipe".
Old 06-11-2015, 01:01 PM
drptop70ss's Avatar
drptop70ss
When i get a chance I will shot a picture of the home made motor mount, welded wheel, and exhaust pipe made out of "pipe".
LOL I bought a 1968 cutlass W30 ram rod that had an exhaust made of black iron pipe. Factory high performance car with a home depot exhaust!
Old 06-11-2015, 05:15 PM
pbsdaddy's Avatar
pbsdaddy
pbsdaddy is offline
Here's some new springs, just a bit cheaper than already shown.
F1 F2 F3 Leaf Spring Replacement, 1948-1952 Ford Pickup Leaf Springs
Old 06-11-2015, 05:55 PM
Bluey Zedoff's Avatar
Bluey Zedoff
Bluey Zedoff is offline
Originally Posted by JPMallory
Wow! That is craptacular.
That word, my friend, suits that job like a silk glove going over a lady's hand.
Craptacular! Love it!
Old 06-12-2015, 08:28 AM
OldGrayMare
Appreciate the info - Thanks
Old 06-15-2015, 05:22 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Spectacularly bad welds too. Somebody needs to short circuit his welder. I thought my PO was bad. I'm still fixing his handwork as I find it.
Old 06-24-2015, 09:39 PM
Scot's Avatar
Scot
Scot is offline
BOOGER WELD!
  #28
Old 07-18-2015, 03:36 PM
OldGrayMare
Thought some of you might enjoy a new picture taken this weekend. Got that PO's nightmare pulled out.
Already picked up another axle, set of springs, and a king pin replacement kit. Just trying to decide if I'm going to remove some of the leafs to lower it before I assemble. Oh - and my helper agreed this will be much safer for cruising.
  #29
Old 07-18-2015, 04:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You might want to use the brakes off that on your "new" axle, as F-100 drums are much cheaper.
  #30
Old 07-18-2015, 05:19 PM
OldGrayMare
Also picked up a set of disk brakes for the front. But I will have to reuse the hubs.
F-1
01-04-2016 10:46 AM
frankishelby
07-18-2012 11:01 AM
emptyd
03-19-2007 10:21 PM
MooseHead Rider
10-19-2004 11:39 AM
Quick Reply: Safety question PICTURE ADDED !
