A/C switching to defroster?
Please add your general local to your profile so's wese nos abouts where U's is
Found my vacuum leak today, vent positions now work perfectly.... I replaced the pump a couple of weeks ago, no change. I had chassed all vacuum lines and everything looked good. When ever I got onto the skinny peddle on the right the defrosters would come on. So every time I had the hood open I looked at vacuum lines, nothing....
Today I took the vacuum tank out ( 3 nuts under the fender well ) and all of a sudden I found the break.... The numb N&ts previous owner had found the break too... He just slid the to broken ends of the line into a piece of rubber vacuum hose and didn't bother to seal it.... Thanks everyone for keep telling me it was a vacuum leak.... IT WAS
Glad you found it and it was a simple fix, but now you have me confused a little.
You said that you replaced the vacuum pump, so that means a deezle right? If so I don't understand why the HVAC would default to the defrost position only when you leaned into the skinny pedal, deezles don't generate vacuum (that's why you have a vacuum pump) so how does the skinny pedal affect the HVAC? On a gasser it would make sense as the vacuum generated by the motor drops off some at higher throttle openings, which would have the HVAC going to the default defrost position.
Am I missing something obvious here?
The system defaults (no vacuum) to open so you will have heat if it malfunctions. Same thing as defaulting to the defroster vents. Gotta keep the windshield clear.
So if you only experience the problem when running on MAX, this is the first place to look.
5Rangers
07-25-2011 09:42 PM
chuck362
11-04-2009 11:21 PM
CALINLEIR
04-28-2009 01:47 PM
