My R&D 7.3l IDI Build
Any updates on the build as well?
UPDATES! YES. The me and the engine builder have FINALLY come to an agreement as to what is going to happen, AND I have ordered the parts from R&D, awaiting shipping. As for the motor, ARP head studs, new bearing and bushing, new pistons, Inconel exhaust valves, head job.. basically everything that would entail a new engine rebuild. To lower the compression ratio, my builder has told me the best way to do it would be a thicker head gasket (even though I don't see why I cant just shave the piston heads bout 0.025 thou). Surprisingly, the bore was only worn out .020 thou, not bad for 570,000km. My R&D order was basically one of EVERYTHING... girdle, stage 2 turbo, RD4-150 pump, cam, intake, etc. uhh... that's about it. As for paint, I'm thinkin CAT yellow with black detailing.
Any other specific questions, go ahead and ask
Yes, I got the 425hp/850lb-ft clutch kit, it finally came in... AFTER 7 MONTHS OF WAITING! AS for the ZF, it was a stock rebuild with bearings and synchros.
My engine build is cat yellow and black as well! I'm still waiting for my parts from r&d also. I ordered my studs a month ago but I guess they're backordered from his supplier. He's shipping the cam and pump with the studs as soon as he gets them in. I guess I gotta keep waiting.
Also what turbo are you going with again?
If your building a performance engine with a bigger turbo and more fuel you should take advantage of this opportunity to lower the CR a little bit... As far as I know there isn't any "thicker" gasket available.. The new cam dose bleed a bit of CR But Not Enough in my opinion. If I where building another Engine I would Cut At least .025 off the Pistons and then balance the weight of all eight again before Balancing the rotating assembly. If your Engine Builder doesn't understand this you have the wrong Engine Guy.. Look up the difference between Static compression and Dynamic compression and the affect Turbo boost has on it... You will soon understand why it is so important to lower the compression ratio on a Engine that will be using more than 10PSI Boost. The more Boost and fuel you add the lower the CR needs to be.. You just need to stay above the Lowest CR that the Engine will still start well... Engine's with 17 to 1 still start ok and will take 30PSI Boost with no problems.. In my application I was shooting for 18.5 to 19.5 to 1 running 20PSI Boost Max so I cut my pistons .030 with stock gaskets. You Can't go wrong with R&D parts so Don't cut corners on the other simple performance mods you can do along the way.... Just my 2 cents...
I understand that the more air you shove into an engine(via boost pressure), the higher the cylinder pressures are. If I put in 24 PSI of boost, my cylinder pressures should be around 3X stock. As long as the head studs can handle the peak pressure, it sure seems like higher CR + higher boost is good, as it means just plain more air in the cylinder.
If you're running into pressure limits(i.e. bending connecting rods or lifting heads), then yes, you obviously need to lower the CR. As long as you are below that point, though...
Why?
That's what I did. If you're talking 300HP range and 30 PSI or less, it should work fine. If you're talking more than that, you might shave the pistons /slightly/, but more important is going to be using PS rods. Remember, rods seem to be the limiting factor here, as Justin found out.
#29
#30
I haven't told anyone this, but I've noticed that my engine seems to rev a bit smoother under heavy load. It used to get a bit rough sounding and feeling up in the 3200+ range; I figured it was timing related, but didn't really worry about it because it still made power.
It smoothed out some since I swapped these new springs in, so it may have been floating valves all along(perhaps holding them open just a slight bit longer), but not enough to bend the pushrod until I got a ton of backpressure in there.
