2006 6.0 Fan Clutch???
Here's my question. My Edge is reading "PO528: Fan Speed Sensor Circ No Signal". When I'm pulling a large 5th wheel up a 4% hill by the time I hit the top (if I don't slow down)warning beeps are gong off and my ECT is at 240. I can hear the fan come in at 215 and it stays in all the way up in temperature.
All the posts say c/o the fan clutch. While that may fix the fault signal, would it do anything for the temp situation. If the fan is locked in it seems like a lot of money just to clear the fault.
Or......is the fan still slipping but sounding like it's working?
This my be not related but I did notice that as the temp rises the AC starts not working. By the time I reach the top of the hill it is blowing hot. As we go down the other side and ECT comes down, it starts cooling.
Thanks for your help. 35 years fixing diesel locomotives didn't prepare me for this truck!
EDIT: Since my truck now never hits 215, I never hear the fan run. I do see the rpms change via scanguage II though. Under 200 I see 600-670 rpm. At 200 I see it climb to over 1000. All at the same engine rpm.
Also, I had a brand new ford fan clutch on it when it failed. It had less than 200 miles on it when I noticed it wasn't working. It blew the seal that is in the case, between the cap that has the part numbers on it and the outer housing. Silicone viscous fluid was everywhere. This was a result of improper storage at the dealer. They must be stored upright or the fluid can get passed the outer seal. My new clutch I purchased from Autozone with a lifetime warranty for the same price as the ford unit. To my amazement, the Autozone unit is the exact same unit ford is selling in, but relabeled in a ford box. The stock for unit has mechanically etched "visctronic" and part number printing. My first replacement from ford had ink printed numbers as did my Autozone unit. Upon further inspection, all of the ink markings, part numbers, wiring codes and plug numbers all matched. The result, Ford is selling aftermarket fan clutches as OEM parts.
Or, there's really only one manufacturer. I learned a while back my local O'Rileys will (in certain cases) order your parts and pick them up from a dealership without mentioning where they came from. I suspect they get a better price from the dealer than "Joe Citizen" would get and they just mark them up a bit.
The other situation is the supplier part is made under a contract to Ford, there is only one supplier and that design is patented and contract licensed through Ford. Both Ford and the supplier will support aftermarket, but Ford will allow the supplier to direct sell with a royalty for a few years until the part is out of Ford's warranty period. Then it's the suppliers ownership.
Ritory
11-22-2010 04:02 PM
