1996 F-SD Crew Cab Build
#61
#62
Everyone around here is like that too. I don't get it. Its like its a state secret or somthing.
I'm like you, I'd want the world to know.
#64
#66
There is an engine builder in east springs that I took a set of heads to back when I thought I could do magic with an EFI scat stroker... He was actually the builder of the motor and the two previous motor that were split in half around the crank. I was more interested in blow through carbed turbo gas motors back then, but he claims 110 psi was going through that motor.
I need to see if I can find the video off an old hard drive so you guys don't think I'm full of a bag of chit, I'm pretty sure I saved it. It was by far the fastest Ford I have seen in person.
#67
#68
Well, i probably jumped the gun starting this thread. Everything seems to take longer than planned! And I am still curious if anyone has heard anything about that s369 turbo yet?
Any how, progress had been made, not on the truck, but on the pole barn.
vapor barrier and mesh down
and the concrete. I could have a pretty nice running truck for the cost of that lol. but i'd just have to work on it outside...
garage door. got a good deal on two of those. 100 bucks a piece, used, with all hardware. insulated too.
wall dividing garage and cold storage
hauling the F-SD
And there it is. The F-SD is in the garage!!
These lights are the led retrofit bulbs. like 50 bucks or something for 4 tubes on amazon. They replace the old florescent, t12 or t8s, and these specific ones are 120v, so they don't need a ballast. just find some old non working florescent fixtures and remove the ballasts and wire the pin sockets for 120v. Nice and bright. It is nice to work in a well lit shop. I still want to add a few more. gotta find some more free 4' fixtures.
The barn needs some clean up outside and other work. still have to cut the tin, so i can use the full 10 ft height if the door, right now the opening is only 12w by 8 tall. So hopefully soon with the 05 f550 axle swap.
hauling the F-SD
#70
#72
#73
