Timing belt or chain or none?
Hi,
I am new to this forum and to the world of mechanics. My partner and I have a '95 ford e-350 short bus school bus with a 7.3 ps diesel engine that we renovated into a tiny home last year. After driving it across the country we are feeling called to do some maintenance and have some questions that I am hoping to get some help with on this forum.
First question is whether this engine has a timing belt or chain or something else?
Also wondering if there is anything else we should have checked or replaced to keep our house running.
thank you! looking forward to engaging with the knowledge of this community.
blessings,
Jessi
blessings,
Jessi
Hi Jessi, welcome to the ford trucks forums!
As 84-250 stated these engines are timed by gears, no chains or timing belts. I'd say the most important maintenance is keep the oil changed with any good diesel rated oil. Motorcraft 15-40 for example, which can be had from Wally's world for fairly cheap. If you read threw the first few threads at the top of the page, you will find a wealth of info in them. These guys can help you threw most any problem you encounter.
Thats bad a$$ thank you...I will try to rep you...but appearently i am not enough of a rep ***** and need to spread it around more...
