Only leaks when it very cold. There will be washer fluid leaking in front of the passenger side of the truck. I believe I saw a tread about this but could not find it . Has anyone eles had this happen to them? thanks
If this is your 2010 in your signature, chances are the rubber is getting old and the cold takes the elasticity away, and it leaks. Replace it, I doubt you can find a grommet only, I don't know. Or pull it clean it, a silicone that sucker in place.
