7 starters in 6 years
#31
#32
Spade vs Ring
There is a known issue with the spade terminal. It is recommended that it be replaced with a ring terminal to avoid bad connections.
Ford Starter Solenoid Spade Terminal
Even have a link where to get this stuff. Fantastic !!
Thanks again,
Larry
#33
Great Pictures
"He possessed beauty without vanity, strength without insolence; courage without ferocity; and all the virtues of man without his vices."
Lord Byron
His epitaph for his dog
Regards,
Larry
#34
Starter Problems
^^^ This. As the voltage goes down, a device will draw more current. 20 years is a long time for copper cables, switches and grounds. I think maybe too there is some work hardening going on, and manufacturers seem to be using dissimilar metals that corrode all by themselves, too. Usually the cable size manufacturers use is just adequate for the purpose when new, but over time the corrosion through the system becomes significant as it is cumulative. It adds up!
It's a bitch to get at them, but it absolutely pays to clean ground points on newer vehicles, to include alternator brackets and hardware, ECU ground, weather-paks, SAE connectors etc. We already know basic stuff like this is required to keep the older stuff on the road. Stay out in front of the newer rigs before somethings expensives get roasted.
Having the same problem continuing. Where are the SAE connections, the ECU ground, weather paks location. I going over this stuff again.
Thanks,
Larry
#35
Starter Problems
I found some grounds not connected on the firewall and some grounds not connect under truck to the frame. I would think that would not help. What other grounds should I check?
Larry
#36
Had similar problems with my '88 5.0 5 speed. PO had gone through starters, replaced the ignition switch, cap, rotor, solenoid, and just throwing NUMEROUS parts at it chasing the issue. I thought they had just replaced some components over the years as maintenance. Nope, they were chasing a starter that was constantly failing when I found the receipts.
The problem was in the starter cable, which was a cheapo Chinese Auto Zone unit. Fabbed one up with top shelf cable and connectors and soldered it all together. Haven't had a problem since, 100% solved.
#37
Starter Cable
Thanks,
Larry
#38
I went an auto electric specialty shop where they rebuild starters/alternators/industrial applications, etc. Told them what I was wanted and they actually built the cable for me while I watched. Took the old cable it as a pattern and after I bought the components they offered to put it together. There was an obvious difference between the auto zone chinese crap and the unit they built. Plus, it wasn't much more than the chinese crap either. $15 maybe?
#39
Good Idea!
I think I will fab one up at an electrical supply place too!
Larry
