Engine Paint Suppliers/Brands
Old 05-27-2015, 10:12 AM
hulleywoodworking's Avatar
hulleywoodworking
hulleywoodworking is offline
I have searched the site and have found very little about who makes a decent engine paint. Lots of stuff about color, but not much about supplier/brand.
I have spray equipment, so I don't need rattle cans.
So where do I buy a qt. of dark red engine paint? What brands are good and which are garbage?
John
Old 05-27-2015, 11:13 AM
Connecticut Calvin's Avatar
Connecticut Calvin
Connecticut Calvin is offline
I painted my 272 over the weekend with Eastwood's engine paint and activator. It hardens like a rock and was even harder after getting cured with a warm engine. Nice bright color too. Take a look: http://www.eastwood.com/engine-paint-kit-26971.html
Old 05-27-2015, 12:40 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,446 Likes on 1,394 Posts
If you have automotive spray painting equipment, good quality automotive paint will work on engines. I've done lots of them over the years, with enamel, urethane, even base/clear.
Old 05-27-2015, 01:30 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
I second the Eastwood. Lays out smooth and has been very durable through 8,000 miles.
Old 05-27-2015, 04:10 PM
fordman75's Avatar
fordman75
fordman75 is online now
I like the POR-15 engine paint.
Old 05-28-2015, 11:49 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Aervoe engine enamel is the best Engine Enamel :: Paints and Coatings :: Industrial, Maintenance, and Construction Chemical Products :: Aervoe Industries Inc.. It is not a common name for most DIYers because it is a commercial product used by professional engine builders. I have been using it for so long I actually forgot where I heard about it but after seeing it on the shelf of two very reputable engine builders I knew that it must be good. This paint sprays on smooth and dries to a high sheen. Colors include both Ford blues and many others. You usually have to buy it in a case of 6 but lately I have been seeing it sold individually.
Old 05-28-2015, 12:16 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
I am another supporter of the two part Eastwood engine paint.
Old 05-28-2015, 12:59 PM
gerrymoe's Avatar
gerrymoe
gerrymoe is offline
I use aervoe rattle cans also, buy it online because more available colors and the search is gone, very hard to find in the stores don't know why. You would be hard pressed to tell the difference from a spray set up application. I have used this on the exhaust and engines with lasting success. My blown Hemi has the black and that motor reaches a temp of 200 constant, no sign of discoloration. I f you need to touch up or anything just grab the can and go
Old 05-29-2015, 07:51 PM
f31951truck's Avatar
f31951truck
f31951truck is offline
engine paint
Try Bill Hirsch restoration products, the paint is aviation grade and is really good stuff.
Old 05-29-2015, 11:11 PM
eb4strom's Avatar
eb4strom
eb4strom is offline
I too will vote for the Eastwood Engine Paint. I just painted my 51 Flathead the "Flathead Red" which looks amazing. I sprayed the 2K paint and thinned it about 15% with a generic thinner. It has an amazing shine and seems pretty hard. I haven't run the engine yet, so I can't say whether it cures any more with the engine heat.
I will also add that I had to touch up a few areas with a brush because I had already started hanging the engine components, and that looks great too.
Old 05-29-2015, 11:16 PM
eb4strom's Avatar
eb4strom
eb4strom is offline
Not to hijack a thread, but Aervoe makes an engine paint?? Is it in a rattle can? Is it a 2K paint? The Aervoe plant is just down the road from my house and I had no idea. We used to buy their "tree marking paint" by the pallet load in the mining industry. Who would have thought that tree marking paint shows up so well on rocks.
Pretty amazing what we learn on FTE (that isn't truck related)
Old 06-25-2015, 02:32 PM
3twinridges's Avatar
3twinridges
3twinridges is offline
I am about to purchase the eastwood aerospray 2K HT ceramic gloss red engine paint for my rebuilt. Its a 1950 226, has anyone used this color or is this even close to the original color red?
Old 06-26-2015, 07:52 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
I think it makes a pretty close match.
Here's their engine red paint pic from Eastwood's site.
This is my oil pan painted Ford Red.
This is someone else's engine.
Old 06-27-2015, 08:46 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
I used Eastwood paint and I'm very happy with the results
Old 06-27-2015, 09:55 AM
aussiecowboy's Avatar
aussiecowboy
aussiecowboy is offline
I use the POR engine paints, it goes on thick and lays out beautifully flat, can't get much easier to use.
Quick Reply: Engine Paint Suppliers/Brands
