Thinking of buying?
Thinking of buying?
Iam looking at a 2000 7.3 powerstroke that has some problems first it is hard to start cranks like it has a dead cyl. Second after starting it has no power not even enough to move. At first it would only run if held wide open but once it warmed up it would idle and rev and move but barly still had a miss. The weird thing is it did not smoke blue black or white also no strong smell of diesel and no smell of oil at all. Truck has 230ish miles and there are no maintenance records.air filter was new.any help would be appreciated.
on
Good advice on the cap trick and pull the intake to see if the wheel is damaged...dusting is bad, chunks missing is even worse.
What kind of air filter is present on the truck?
When you look at the truck again, see if there is any black residue in the degas bottle/coolant reservoir. If you pull the fuel filter, see if it is yellow-ish brown or if it is black.
milkstake
13
12-01-2018 03:46 PM
qhnut
13
06-26-2006 09:06 AM
