Rotella T6 is good for more than just your truck
I had been using Mobile 1 Turbo Diesel Truck 5W-40 oil in my 6.0, six gas generators, the Cat C7 in my motor home with a Kohler diesel generator and two riding lawn mowers with Kohler gas engines, but it wasn't suitable for my Suzuki four wheelers due to not having the right additives for the clutch pack primaries. I wanted one oil I could use in everything so I didn't have to remember what oil was in what or carry more than one type of oil worrying about someone putting the wrong oil in something.
I had been using Mobile 1 10W-40 synthetic 4 cycle motorcycle oil with the right additives to meet the JASO MA requirements for the four wheeler wet clutch primaries.
I started looking at the Rotella T6 synthetic 5W-40 oil and it also meets the JASO MA standards of the four wheelers. I'm now starting to change everything over as oil changes come due. Some of the toys may not require this expensive of an oil, but it makes life a lot easier.
Bill
Bill
I had lower engine temps with a 32:1 ratio, while others had higher temps running 25:1 with the other "good" oils.
not that it means much to your application, but I was using Klotz 2-stroke oil in a large-scale R/C desert buggy with VERY good results. The quality of the oil was a big upgrade from the usual contenders. If their engine oil is anything like the stuff I was using, I think you will be happy with the results.
That is why I am trying the Klotz in the Mustang.
