2001 F450 A/C recharge
I think the truck needs a recharge, it's not blowing any cold air. The question is - which port do I use? There's one on the top of the accumulator and another in the line just off the passenger side of the radiator, near the coolant tank.
My only recharge experience was after I replaced a leaking accumulator in my 2007 Crown Vic police interceptor, and this obviously doesn't look quite the same.
I've got the gauge and hose that goes onto the refrigerant can, I'll have to match it up to the correct port on the truck.
on
The low side is the large port on the accumulator, closest to the firewall, remember 134a runs higher pressure than r-22. on an average day 60-70's you want 45-50 on the low 250 on the high, dont panick if the high is up there when your driving the air rushing thru the condensor will drop the pressure.
Wait for it to warm up, your charge will be more accurate. Usually, a high side pressure about 2.2 times the ambient temperature in °F will put you right in the ballpark.
If they weren't, that metal can would turn into a hand grenade when pressurized to over 200 psi if connected to the high side.
That they would be different sizes never occurred to me.
Quote:
{That they would be different sizes never occurred to me.}
