Leaky injector 460
Old May 19, 2015 | 07:52 AM
zackcj7's Avatar
zackcj7
Leaky injector 460
I tried searching but had no luck...
I have a '94 F250 with a 460. I noticed when I checked my oil last weekend that the manifold was wet around the second injector on the driver's side. Plus I see some fluid, most likely gas, in the manifold valley close to the injector. I'm guessing the 0-ring on the injector needs to be replaced?
Any tips for doing this repair? Any kind of special tools needed? I'm not very experienced with working on fuel injection.
Old May 20, 2015 | 07:20 AM
zackcj7's Avatar
zackcj7
94 Views and no replies? Is fuel injector failure really that uncommon on the 460?
Old May 20, 2015 | 06:24 PM
TobaccoBarn460's Avatar
TobaccoBarn460
Zack, take a look at the head of this forum under the "tech notes" for the fuel injector removal and cleaning.
If you do have a leaking o-ring, you should consider servicing all 8.
If you go on E-Bay to order the Bosch EV-1 kit, tell the supplier to send you the kit for a 460, which includes the "hat".
The procedure is to remove the fuel rail, so everything above that, upper plenum, etc. has to come off.
Old May 23, 2015 | 10:41 AM
zackcj7's Avatar
zackcj7
Thanks for the link, some good info there.
Had a chance to look at it closer this morning. I'm no longer sure it's the injector that's leaking. It may be the small piece of hose that connects both sides of the fuel rail together. I cleaned the intake and around the injectors so everything is bone dry. I let it run ten minutes and no leaks. I'm going to drive it some and check again.
UNTAMND
May 6, 2010 09:13 PM
go2toa
May 15, 2007 04:50 PM
MustangGT221
Jan 8, 2007 10:43 PM
someday
Dec 27, 2004 09:11 PM
rwdoughty
Dec 17, 2003 12:10 AM
