Engine Hiccupping...
Old May 17, 2015 | 06:50 PM
Grems4ever's Avatar
Grems4ever
Will do. I'm also going to be tracing wiring looking for shorts...
Old May 18, 2015 | 08:49 PM
Grems4ever's Avatar
Grems4ever
Yep - Definitely electrical issue. Drove it a short distance over some dirt roads to pick-up a lawnmower and it acted all sorts of stupid. Have I mentioned I dislike tracing out electrical problems?
Old May 19, 2015 | 04:04 PM
ZarK-eh's Avatar
ZarK-eh
I would start by running the engine, and manhandling the wire harness, and each connector. But not so hard you hurt it, or yourself on moving parts...
If something hiccups while your doing that, great! you can narrow it down some.
If Not, then maybe go through each connector looking for anything obvious, like corrosion on the Throttle Plate Sensor Connector. Use a bit of spray lubricant to help pull the connector apart and some small screw drivers.
Hoping it's something obvious you can easily spot and repair... And try not to despair about wiring, it knows when you hate it
Old May 19, 2015 | 06:53 PM
Grems4ever's Avatar
Grems4ever
That's the plan for this weekend. Not sure where to start though - I guess grounds are as good a place as any...
Old May 19, 2015 | 07:29 PM
Grems4ever's Avatar
Grems4ever
Found it!! Well sort of...
I went out and performed the wiggle test and discovered that the problem is in the connector to the ECM. Wiggle the wires and it goes all sorts of stupid. Now I need to decide how to fix it...
Old May 22, 2015 | 01:26 PM
Grems4ever's Avatar
Grems4ever
Complete engine harness has been pulled from the truck. Lots of corrosion in the pins on the connector to the control module - so much that you can see it coming up from the wire side. I certainly hope this is the exception more than the norm or I may have fun finding another one.
Old May 22, 2015 | 03:27 PM
vloney's Avatar
vloney
Now, mix that with a 2015 f250 diesel. Customer blue in the face mad, "I paid $65.000 for this and I can't drive it!". When you have that, you've got a "time limit", until he blows a gasket. Then, you find ONE pin in the 120 for the pcm that fits loose.
Old May 22, 2015 | 03:31 PM
Grems4ever's Avatar
Grems4ever
Yeah - that's a nasty mix all right Vince. Can you fix the pin or have to order a complete replacement harness?
Old May 22, 2015 | 07:47 PM
vloney's Avatar
vloney
They do make replacement pins. You have to remove the bad one from the connector (intricate work) match up the correct replacement, splice in the wire, then re-install.
Old May 24, 2015 | 07:52 PM
Grems4ever's Avatar
Grems4ever
Replaced the entire harness with a good looking one from a junkyard and it still cuts out. Upon closer inspection on the "remanufactured" engine control computer, it has several loose pins in it. I'm getting another under warranty, but it won't get here until Thursday...
This is just plain frustrating...
Old May 24, 2015 | 08:27 PM
vloney's Avatar
vloney
I had an 08 f250 6.4 with 2 pins close together (one 4 volts, one 13.5 volts) When those shorted together, all hell broke loose.
Old May 24, 2015 | 09:47 PM
Grems4ever's Avatar
Grems4ever
So far I've found 3 - 2 are involved with diagnostics and the other is the fuel pump.
When I get it back together again, I'm hesitant to take for a test drive. For a brief moment it will be fixed and I don't want to know if it isn't.
Old May 29, 2015 | 08:30 PM
  #28
Grems4ever's Avatar
Grems4ever
Progress!
I stabbed in the replacement engine control unit in this evening and it seems to have solved the problem. I've slammed the doors & hood, driven it at freeway speeds, and have found the bumpiest roads I could and it has yet to miss a beat.
Old May 30, 2015 | 01:28 AM
  #29
ZarK-eh's Avatar
ZarK-eh
Most excellent!
Corrosion isn't that great for conducting electricity! I like using white grease and dielectric grease to help protect the connections. Especially if there is a lotta moisture and water.
Old May 30, 2015 | 05:51 PM
  #30
Grems4ever's Avatar
Grems4ever
Put just shy of 200 miles on the old girl today and it ran like a top.
Hopefully it will stay that way for a while...
hltnmtthw
Jan 1, 2018 05:33 PM
1988
May 5, 2014 08:15 PM
eyancey
23
Sep 17, 2009 07:43 PM
sainty333
Dec 19, 2006 04:51 PM
hatch_1989
20
Sep 28, 2005 06:51 PM
