6.0L
Old Jun 3, 2015 | 06:56 PM
04badford's Avatar
04badford
OH and double check that Thermostat it could be closed , did you go with OEM?
Old Jun 3, 2015 | 07:05 PM
WatsonR's Avatar
WatsonR
In a couple posts down from the top....says ECT was staying at 198. If the pump wasn't working, it would probably have melted already. 258 is defuel.
With all the oil coolers in and out... the OEM oil cooler is not in the block, correct? It was removed and you used a what brand external cooler, 2 weeks after the second one was in.. why? Was it showing signs of clogged up or large split between temps?
If the oil cooler doesn't have clogged passages, it has to be the bypass.
Old Jun 3, 2015 | 07:11 PM
04badford's Avatar
04badford
True True I Must have speed read over that one
M3rc
May 18, 2019 03:22 PM
quietman
Apr 21, 2019 12:22 PM
quietman
Apr 19, 2019 12:10 PM
Race88f550
Mar 19, 2012 07:43 PM
04F-250mark
Nov 23, 2011 04:26 AM
