08 Expedition El...A/c not working
I have read through most of the posts. I am new here and looking for some help with my A/c issue. It is not blowing cold air. I checked the lines and they are warm. I noticed the clutch a little loose and tightened that up. I checked compressor and there is voltage there. I then decided to check relay socket and power there. I next checked a/c clutch fuse and there is no power to the fuse. Fuse is good just no power. Now I am stumped as to where to go next to find out why there is none there. Any suggestions?
i did check that before i started tracking down the no power issue. Just not sure what switches and their locations i should check next. I may try a new relay. Like i said i have power to the relay i just do not have power to the fuse and the fuse is good. Been trying to find some sort of wiring diagram or A/C setup to show wiring and switches,relays,fuses,etc..and their locations but i'm coming up empty handed
