What are the best years for a donor frame for my project?
Hi, guys and girls . This isn't usually where I hang out but i have a ranger question you. I have a 1950 Ford F1 cab and frond clip that I have been playing with for many years. I have had it on different full-size frames over the years( 2 and 4 wheel drive). Im thinking this next part of its life I might try a ranger frame to keep the tires under the fenders. My question is what do you guys that drive them think the best 2wd ranger frame is , based on strength, ease of wheel alignment with 302 installed and things like that?
I personally can't answer your question with any specifics, but you might find this article informative:
Ford Ranger History
Note that, beginning in 1998, Ford changed over to a SLA front suspension, and the length of the wheel base was also increased.
Ford Ranger History
The 1950 is 114" according to some info I found.The closest ranger I found was a standard cab long bed at 117", so i could work with that. If Im reading correctly there were torsion bar suspension and coil spring suspension in the later years. Which of those do you guys think is better? Just a 2wd street truck with a 302 is all I want to build.
Check out: Ford Ranger Suspension through the Years
One thing to keep in mind is that, torsion bars makes changing out the lower control arms on a Ranger more difficult, because the bars travel through the arms.
SunDown
09-19-2009 10:45 AM
stillwaterharmon
03-17-2005 04:08 PM
4T8ford
02-28-2003 02:25 AM
