4.6 f150 to 7.3 powerstroke?
Old 05-08-2015, 08:54 AM
Fordkindagirl97's Avatar
Fordkindagirl97
Fordkindagirl97 is offline
Lightbulb 4.6 f150 to 7.3 powerstroke?
So I've got a bright idea to convert my f-150 to diesel. Any ideas on what exactly would have to be changed along with the engine, trans, rear end, and suspension?
Old 05-08-2015, 09:23 AM
dustyroad's Avatar
dustyroad
dustyroad is offline
never been asked about ever. No one has ever done it here.
Old 05-08-2015, 09:45 AM
Fordkindagirl97
no one has done it around here either, but i really am looking into it. truck needs a new engine anyways so why not make it unique?
Old 05-08-2015, 09:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
You'll need the engine, transmission, rear axle, front suspension, computer, wiring, and instrument cluster. Then you'll need to make it all fit and work together. It can be done, but it isn't going to be easy or cheap.
Old 05-08-2015, 09:59 AM
dustyroad's Avatar
dustyroad
my sarcasm went right over you head.
You're not the first person to ask this or do this. Just use the power of the internet and you will find complete how to's I'm sure.
Because this question is asked about once a week here.
It's the new flavor of the month, lets put a diesel in there.
Old 05-08-2015, 11:58 AM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Originally Posted by dustyroad
my sarcasm went right over you head...
FYI, sarcasm almost never comes across correctly in writing. Using a might help some. But if you are hoping to communicate on a bulletin board, don't use sarcasm. If you're just looking to make a cute, snarky comment, then fine, go for it. But not to communicate.
Old 05-08-2015, 07:08 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
See post 4.
And:
https://www.ford-trucks.com/forums/1...-7-3-swap.html
This seems like a good idea at first. But these engines and transmissions weigh about twice what your oem motor weighs.
Lighter, smaller engines might be a better choice, such as the 4BT Cummins or a 5 cylinder Mercedes. None are free, and you are really doing more than an engine swap in converting a gas vehicle to a diesel. Note in post 4 the inclusion of wiring and instruments as items that need to be changed.
IMO if you want a diesel pickup, buy one.
Old 05-08-2015, 11:38 PM
co425's Avatar
co425
co425 is offline
+ 1 with the above. F-150's are too light duty for an engine such as a 7.3 or cummins. A 4bt or one of the other small diesels would be more appropriate. You have to consider that the weight will all out wear on your other front end components as well.
Walter Wood Jr.
02-21-2017 06:16 AM
Yukon_IDI
02-22-2015 09:10 AM
Redneck1465
04-23-2008 03:43 PM
Ford4Fun
Engine Swaps
20
05-12-2004 06:10 PM
DARISS
05-12-2003 11:12 AM
Quick Reply: 4.6 f150 to 7.3 powerstroke?
