83 f150 4.9 oil pump problem?
Recently went thru the job of replacing my oil pan gasket, what a PIA. Anyhow, replaced the pick up tube and the oil pump while I was in there. Now the dizzy rotor is hitting the cap. Ever so slightly but I have some plastic wear on both. Does not seem to affect the engine but apparently the pump did not seat right. It seemed to seat to the block ok when I torqued it down and engaged in the dizzy shaft because my oil pressure is ok. Actually better with the new pump.
Check the adapter
I'm not familiar with the dizzy components for your application, but if it is a 3 part assembly, Cap/Adapter/distributor body I would bet your adapter that has 2 adapter retainer clips (one on each side) got tweaked and needs to be taken off and reinstalled, if this is not seated/oriented correctly it would cause the rotor to hit one side
Yes, it is the three part version. I previously checked the adaptor and it is held down by two screws to the main body and it is is tight. This problem came up only after I replaced the oil pump. The engine was running ok after I replaced the pump. I had just failed an emissions test and was doing a major tune up including replacing the cap and rotor otherwise I would have never noticed it.
jeff8362000
11-09-2009 08:59 PM
allen410
11-24-2004 10:26 PM
