Show Your Truck W/ Bumper Pull Camper Here.... - Page 60 - Ford Truck Enthusiasts Forums
  #886
Old 08-31-2018, 07:41 PM
Ford1dawg
Ford1dawg is offline
Ford1dawg is starting off with a positive reputation.
Specs
https://www.rvusa.com/rv-guide/2017-dutchmen-coleman-light-travel-trailer-floorplan-2405bh-tr32850
  #887
Old 09-01-2018, 09:47 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
We just pulled in this last weekend from our last trip of the year.
Rig still looks the same as it always did. lol
  #888
Old 09-01-2018, 09:51 AM
FordmanNJ's Avatar
FordmanNJ
FordmanNJ is offline
FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.
@Ford1dawg You have a newer 150. It might be better worse same or anything in between. However it if was coming from an older 150 like I did then it would be a world of difference. I towed our first trailer (30 foot 6K Kodiak TT ) with a 99 F150 XLT 5.4L V8 SCSB down to Florida and back in 2012. It was a an interesting ride. The following year, my wife and I upgraded to a 2011 F250 6.2 and had a trip to Myrtle Beach, SC planned for the summer. That was a world of difference when it came to the towing portion. If anything you are going to gain in payload between to the 2 trucks. However best of luck with the new ride and trailer.
  #889
Old 09-01-2018, 11:11 AM
Ford1dawg
F150 with 28ft TT
I am wondering if I will feel the wind or big trucks as much? My F150 pulled great, and stopped great. We have pulled trailer over the mountains here in Ga, and pulled to Myrtle Beach. Crosswinds and semi trucks running 80 would sometimes give me white knuckles. I am thinking the bigger heavier truck will help with that some. I do run a WD hitch and sway bars.
  #890
Old 09-01-2018, 05:34 PM
JD'sBigredv10
JD'sBigredv10 is offline
JD'sBigredv10 is gaining momentum as a positive member of FTE.
My previous trailer was 30 feet and 7500 pounds loaded. Towed it using the same Equal-i-zer hitch (properly adjusted) with the the 2016 F150 3.5 EB Max Tow and the 2005 V10 F250. Both engines were were great at moving the load but the F250 was by far my preferred tow rig. The F150 was fine but I could definitely feel the trailer behind me. A 7500 pound trailer can exerts more influence on a 5400 pound truck than a 8000 pound truck. My current trailer is 35 feet and 9000 pounds. I would not even consider hitching it to my F150.
  #891
Old 09-02-2018, 11:43 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Originally Posted by CarterKraft View Post
Not to be nosy but the 220FB spec here lists your trailer at 9500 GVW, are you really loading it to 11K? Maybe that is the wrong spec for the trailer.
My trailer is 36' long 12' tall and around 11K without toys and has a 13K GVW, definitely dually territory after pulling it for 4 years with an Excursion.
Mine is not the ASV model. I have the 2006 brochure and don't see an ASV model listed. 11K is the GVWR on my sticker, which agrees with the brochure.
  #892
Old 09-04-2018, 03:59 PM
CarterKraft's Avatar
CarterKraft
CarterKraft is offline
CarterKraft has a very good reputation on FTE.CarterKraft has a very good reputation on FTE.CarterKraft has a very good reputation on FTE.
I see here the is a S2 and S4 both 220FB but the S4 has the higher 11K weight rating.
Thanks for the clarification, I have been trying to figure out if my trailer is unusually heavy or if I have too much junk in it.
For 10' more feet of trailer and a Super Slide I am inline with your trailers weight rating I think.
  #893
Old 09-05-2018, 10:38 AM
davidpacificnw
davidpacificnw is offline
davidpacificnw is gaining momentum as a positive member of FTE.davidpacificnw is gaining momentum as a positive member of FTE.
Originally Posted by Stewart_H View Post
Ease up with the clap-back brother, he didn't mean it in a negative way. Most people don't realize all Excursions came with a 44 gallon tank. You could have explained and qualified your statement after-the-fact without the denigration. We're not normally mean spirited here and emotions and intent can be read into a persons post where something negative wasn't meant. His post wasn't poking fun at you, but was meant as one of those "illuminations" that turns out a bit humorous and makes a person smile and go, "OH!"
At least that's how I took it.
Either way it's all good. Just wanting to assuage any negative feelings that may have been stirred up. Nothing negative was meant towards you.
Stewart
Except for the fact that I clearly stated that I had an excursion as a company car. So, the comment was simply calling me a liar then and that's okay? Sorry if I triggered the snowflake alert. There should be a law against allowing people to access "the inter webs" from their parent's basement.
  #894
Old 09-06-2018, 02:24 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Sorry, I missed that. In fact, below is your quoted post (minus the pictures) that he referenced and I don't see where you advise you have an Ex as a company car?
LOL. All you're missing is the fuel tanker that thing must need to stay on the road. Quite a load there.
If you posted the info in earlier post, you can't expect users of FTE to remember every detail of every user that posts information about their vehicle, and then to recall that specific info before posting so their info is correct.
Again, he didn't call you a liar, but if you can't see or understand how I was trying to assuage any negative feelings you may have felt, then this post will probably fall on deaf ears too because the snow might be falling, but it's not falling where you think it is.
Anyway, just grow thicker skin and stop taking umbrage at a perceived jab. There was none.
Enough said, nothing to see here....lets move along.
Stewart
  #895
Old 09-09-2018, 11:52 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Too old to be too smart
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Wise ol' bacon-fryer your are! Thanks for keeping this thread straight and progressing forward.
Pop
  #896
Old 09-17-2018, 01:44 PM
alabamatanker's Avatar
alabamatanker
alabamatanker is offline
alabamatanker is starting off with a positive reputation.
2018 F-250 Powerstroke, 2018 35' Heritage Glen LTZ
  #897
Old 09-18-2018, 08:43 PM
skoryd
skoryd is offline
skoryd is starting off with a positive reputation.
A few photos from a recent long weekend at the beach.
Size:  1.34 MBName:  photo711.jpg
Size:  1.31 MBName:  photo760.jpg
  #898
Old 09-18-2018, 09:10 PM
avf100's Avatar
avf100
avf100 is offline
avf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to beholdavf100 is a splendid one to behold
Where's the beach ??
  #899
Old 09-19-2018, 08:05 PM
skoryd
skoryd is offline
I took some photos while on the actual beach, unfortunately none of them included my truck & camper..lol
Here's a shot that my wife took from the passenger seat while going over the St Johns river on the way to Jacksonville Beach. At least it includes the camper, truck and some water.
  #900
Old 09-25-2018, 12:58 AM
MissileMech's Avatar
MissileMech
MissileMech is offline
MissileMech is starting off with a positive reputation.
Just before hitting the CAT scales
Quick Reply: Show Your Truck W/ Bumper Pull Camper Here....
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
