Show Your Truck W/ Bumper Pull Camper Here.... - Page 44 - Ford Truck Enthusiasts Forums
Old 01-12-2018, 11:45 PM
HRTKD's Avatar
HRTKD
HRTKD is online now
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Originally Posted by First Dually View Post
Ah, OK. Understood. If loading my stuff in the truck bumps into the maximum cargo carrying capacity, I just move the wife into the trailer. For best weight distribution, she should be well behind the trailer's axles. Got it.
Well now, there you would be wrong. Or, possibly wrong, depending on the girth of said wife. Placing too much weight behind the axles of the trailer could lower your tongue weight. On the off chance that you wife is named Big Bertha, but not to her face of course, you could cause some significant sway problem. Ah, that's sway of the trailer, not of Bertha's ample hips. Too light of a tongue (that's the trailer's tongue) is almost a guarantee that the trailer is going to sway.
The general rule of thumb is that there must be 10% of the trailers weight on the tongue to eliminate as much sway as possible. The more tongue weight the less likely the trailer is to sway.
The easiest way to get to 10% is to have your trailer weighed when it is fully loaded and ready to head out for camping (water, propane, supplies, etc). A tongue scale comes in handy here, but only to get the actual tongue weight. Look for a CAT scale nearby, usually at a truck stop.
  #647
Old 01-12-2018, 11:56 PM
First Dually
First Dually is offline
First Dually is gaining momentum as a positive member of FTE.First Dually is gaining momentum as a positive member of FTE.
Can't I just estimate what the cat weighs? Say maybe 15 pounds?
  #648
Old 01-13-2018, 12:07 AM
HRTKD's Avatar
HRTKD
HRTKD is online now
While I doubt your cat is trained well enough to sit in one place long enough to be weighed (without sedatives involved) an estimate in this case is probably sufficient. The cat may not be happy riding in the trailer, especially if use of the litter box during transit is required.
  #649
Old 01-13-2018, 03:15 PM
meborder's Avatar
meborder
meborder is offline
meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.
So the litter box should ride in the truck!?!?
Man am I glad I don't have a cat!!!
  #650
Old 01-13-2018, 03:31 PM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
That's why we have two cats. They don't mind staying home, while a dog would throw a fit and destroy the house if left behind. Two cats equals twice as much not caring.
  #651
Old 01-15-2018, 06:50 PM
dmarch's Avatar
dmarch
dmarch is offline
dmarch is starting off with a positive reputation.
2015 F-350 and 2018 Lance 1995
Took advantage of warm weather today and cleaned the truck and trailers.
  #652
Old 01-15-2018, 06:54 PM
dirthawg's Avatar
dirthawg
dirthawg is online now
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
Warm weather? Did it warm up to +2 today?
Down here it's cold when water turns to a solid.
Nice looking rig by the way
  #653
Old 01-18-2018, 08:18 AM
wingdavid
wingdavid is offline
wingdavid is starting off with a positive reputation.
1997 F350 XLT 7.3 CCLB dually with Montana mountaineer 335RLBS
2008 F350 6.4 Lariat CCLB with Jayco eagle 330RLTS
2018 F250 XLT 6.2 /4.3 locking SCLB 40 console 40 seats upfitter camper springs on order due Feb 8 2018
  #654
Old 01-18-2018, 07:47 PM
machmedic
machmedic is offline
machmedic is starting off with a positive reputation.
Nice combo wingdavid.
  #655
Old 01-23-2018, 04:53 PM
TrippinStfflr
TrippinStfflr is offline
TrippinStfflr is starting off with a positive reputation.
2017 Keystone Hideout 28BHS-Husky Centerline WDH
2017 Ford F250 XLT Premium 6.7L CC Blue Jean Metalic--25% Ceramic Tint in front, 15% factory tint in rear
  #656
Old 01-24-2018, 12:04 PM
Eric Henry
Eric Henry is offline
Eric Henry is starting off with a positive reputation.
Our '01 7.3 with a 30' camper and 16' utility trailer. Play hard!
  #657
Old 01-24-2018, 01:04 PM
Buliwyf
Buliwyf is offline
Buliwyf is gaining momentum as a positive member of FTE.Buliwyf is gaining momentum as a positive member of FTE.
Guys that are close to cargo capacity but under trailer capacity will throw stuff (firewood, generator, luggage, wife) in the trailer instead of in the truck.
I have the opposite problem. My ATV weighs in around 1,400 lbs. If I want to put any water in my trailer's fresh water tank then I start pulling stuff out of the trailer and into the bed of the truck.
That's what I've always done as well. I'd rather overload the truck, than the trailer. As long as my airbags can level the truck.
  #658
Old 01-29-2018, 04:21 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
Impressive setup. Kudos on your choice for parking.
  #659
Old 02-03-2018, 01:42 AM
CSDenny
CSDenny is offline
CSDenny is starting off with a positive reputation.
Just picked it up today...
2018 Eagle HT 24BHTS with F350 Platinum CCSB SRW
  #660
Old 02-03-2018, 11:43 AM
ExPACamper
ExPACamper is offline
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Nice!
Quick Reply: Show Your Truck W/ Bumper Pull Camper Here....
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
