spark trouble on my stock 352
Hi, This is my first post on the forum. I have a problem that I just can't seem to track down. My stock 352 motor is misfiring 90% of the time on one cylinder and about 30% of the time on another. It does so at any rpm and today I tried to track it down. I put my timing light on each wire to see if the misfire was electrical and it seems to be. I check the plugs and even switched two and the misfire stayed in the same cylinder. I put new plug wires on, same thing. Switched the plug wires but the problem didn't move. So I figured it is the distributer cap and rotor button. This seemed like a sure thing since the two problem cylinders are fired by adjacent positions on the distributer.
I put the new cap and rotor button on and the problem remains. I can't figure what to check next.
Some backstory that may help. The problem started after I did a complete tuneup including some carb work and compression check. I have rechecked the carb to see if the problem lies there, but everything checked out.
Any help is much appreciated!
problem solved, but would like to understand how!
Thanks for the advice on the plug wires. I had previously checked that in my troubleshooting.
Tonight, I messed with the points and restarted the engine. The problem remained but manifested in different cylinders. I changed out the points and condenser and the truck purrs perfectly. Problem solved!
I am curious to know why, if the points were bad, it was only affecting a couple of cylinders. Any thoughts on that?
71LTD390
11-28-2008 06:47 AM
cleanLX
18
12-26-2005 08:38 PM
MARC
02-22-2005 01:57 AM
