HELP! Washed engine bay, now won't start!
Old May 4, 2015 | 10:18 AM
Jrgunn5150's Avatar
Jrgunn5150
I used Wd40 in the cap to keep it working
Old May 4, 2015 | 10:54 AM
NorthwestX360's Avatar
NorthwestX360
Originally Posted by grandpas1974
Yes, you understood my southern slang correctly. The engine does turn over but won't start.
Ah, okay. To me, "Won't crank" means the starter is not isn't doing anything. Sorry if I caused any confusion.
Old May 4, 2015 | 08:01 PM
grandpas1974's Avatar
grandpas1974
Took dizzy cap off and blew it out with compressed air, shot some WD40 in and wiped down. Also blew out all connection points with air and made sure contacts were clean. Fired up first time and ran great. Took her for a drive and all looks good. Thanks guys! Probably won't hose down the engine again in the near future 😜
Old May 4, 2015 | 08:08 PM
Jrgunn5150's Avatar
Jrgunn5150
Lol, just use some care and it'll be OK, I hosed down the 5.3 in my Trailblazer today.
Old May 4, 2015 | 08:38 PM
sporkacus's Avatar
sporkacus
I'm glad I read this thread as I was just about to do some spring cleaning. Glad it got all worked out!
Old May 4, 2015 | 09:53 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Read this one to then. https://www.ford-trucks.com/forums/1...-old-mess.html
Old May 4, 2015 | 10:02 PM
HIO Silver's Avatar
HIO Silver
When power-washing an engine, I'll use sheets of aluminum foil around the dizzy because it conforms and stays in place better than a plastic bag.
If you're gonna use engine heat to dry the engine, steam and condensation can still form under the distributor cap.
I'll usually just let it air dry and use rags to sop up water in the horizontal nooks and crannies.
Old May 4, 2015 | 10:40 PM
Don Naslund's Avatar
Don Naslund
I find it helpful to soak a towel in cold water and wrap the towel completely around the distributor to block the steam from getting under the distributor cap. Also don't spray the alternator.
Old May 5, 2015 | 05:42 AM
vtpkrat2's Avatar
vtpkrat2
I do not avoid washing an engine or engine compartment. Gunk them down with cleaner,spray them down with the water hose or at times pressure washer. Avoid if possible direct water on alternator and electrical stuff. When done I grab the air hose and blow everything off especially distributors and electrical boxes etc. This is the same advice everyone else is giving, just my 2 cents. gary
Old May 6, 2015 | 03:34 AM
rockittsled's Avatar
rockittsled
Originally Posted by Jdeshler
But to clarify, I have all my teeth, don't dip, am NOT an Alabama football fan and keep my grass cut
Born and raised in CA, Dad was stationed at Castle AFB twice, I was stationed at Beale AFB when I was in, and worked at McDonnell Douglas in Long Beach on the MD-11 after I got out of the USAF, and eventually ended up in Dothan for a few years. First time I heard some people talking about "fun times in LA", I started talking about the times I had. They looked at me like I was stooopid. One explained what "LA" "really" meant... I looked at them like...well... Your statement covers it
Bondora68
Jan 4, 2019 12:25 PM
gnwalker
Electrical Systems/Wiring
Jan 27, 2010 05:52 PM
djc212007
Feb 8, 2008 11:17 AM
DSalmon
Jan 24, 2004 09:56 PM
hoggylee
1978 - 1996 Big Bronco
Feb 2, 2001 09:23 PM
