primer suggestions??
Old May 2, 2015 | 08:19 PM
rollingthunder77's Avatar
rollingthunder77
Smile primer suggestions??
hi everyone i have been working on the body of my sons 1977 f150 and within the next month me and him will be priming it i have a spray gun and a large compressor so i believe i have everything just wanted to know what you guys recommend using as a good primer
Old May 2, 2015 | 08:24 PM
lafermedavid's Avatar
lafermedavid
epoxy primer....that some good stuff,and then 2k high build,eastwood,southern poly just to name some suppliers.
Old May 2, 2015 | 08:51 PM
Blue and White's Avatar
Blue and White
I second the epoxy over clean steel. Its the best. There are other choices if dealing with non structural rust.
When spraying, keeping the water out of the air is important for a good job. Approaches are 1) a long run of metal pipe (eg 100') to cool the air and a water separator at the end 2) A refrigerated chiller to cool the air and drop the water 3) A desiccant dryer.
I went with the desiccant dryer as I did not have a long pipe run and did not want to buy a chiller... after I had water problems on a project.
Old May 2, 2015 | 08:57 PM
HIO Silver's Avatar
HIO Silver
Paint materials should be treated as a system. Meaning, the primer surfacer, sealer, color coat, and clear should come from the same manufacturer... talk to your jobber or review Summit's paint systems for info.
2x epoxy primer.
JimG1098
Oct 27, 2009 02:44 PM
thelonerangerxlt
Paint & Bodywork
16
Jan 15, 2008 05:49 PM
Herman R
Paint & Bodywork
Oct 8, 2007 10:57 PM
Scott Fraser
Paint & Bodywork
Jul 7, 2004 02:48 PM
notmrbig1
Paint & Bodywork
Dec 18, 2003 12:38 PM
