Starting problem
Old Apr 27, 2015 | 05:50 PM
HawaiianPSD's Avatar
HawaiianPSD
Starting problem
Friends truck, 06 with 135k. Problem he's having is, truck cranks over fine but doesn't fire, if he kick starts it, it fires right up. Haven't had the chance to put my AE on it, figured I throw it out there. Any ideas guys?
Old Apr 27, 2015 | 05:52 PM
WatsonR's Avatar
WatsonR
Kick start? As in Jump start? If he's jump starting it's batteries and alternator.
Old Apr 27, 2015 | 07:09 PM
HawaiianPSD
No not jump, he has to kick it (roll and pop clutch). Batts and alt were tested, they're good.
Old Apr 28, 2015 | 07:47 AM
WatsonR's Avatar
WatsonR
And the starter?
Old Apr 28, 2015 | 10:51 AM
HawaiianPSD
Originally Posted by WatsonR
And the starter?
Starters good.
Old Apr 28, 2015 | 11:08 AM
WatsonR's Avatar
WatsonR
That doesn't make any sense. Truck won't start by the starter, but will if you dump the clutch. Batteries and alternator are good. Dumping the clutch spins the flywheel, same as the starter. Is it getting 150+ rpm by starter? How about ICP, at least 500? Cam synchronization?
Old Apr 28, 2015 | 12:06 PM
npccpartsman's Avatar
npccpartsman
Sounds like the starter isn't turning enough RPM's for the fuel to be commanded on.
Old Apr 28, 2015 | 08:43 PM
Dr. Beeker's Avatar
Dr. Beeker
I would also check the FMP is above 46 when cranking, it could be the FICM is week or bad solder joints
Jdeshler
Nov 12, 2016 08:09 PM
Smokey Chubbs
Jun 22, 2013 03:55 PM
7.3lpowerstroke
Oct 19, 2011 05:51 PM
superman0604
1978 - 1996 Big Bronco
22
May 28, 2004 01:34 AM
